Team Magic E4 Thread
#2521
Hi Roy, just got reply from that smart guy. Here are some thing you need to do:
1. Lathe a new shaft (I uploaded some pictures, the one with title of "two speed mod" and shows two shafts, the lower one is the shaft he lathed, upper one is the original E4RS part) and it must be thicker.
2. A Kyosho TF2 two speed shaft kit
The reason for thicker new shaft is to let the TF2 shaft (black one in the picture) can go through, and then use pin or screw to fix two shafts together. He used Kawada's spur gears, but I think any spur which can fit TF2 shaft will work. The pinion gears just need a little modification then you can put two in the motor shaft. I hope it helps
#2522
Did you see the servo modification? I think it is pretty neat. They used Futaba S9551 in the car, but said BLS551 will be better. They claimed that it can make the motion smoother and better. I just ran my E4JS last week and didn't find anything wrong with the steering, so have not thought about this mod. But if you guys are looking for something to improve your cars, it may be worth trying
#2523
SInce I use the Wolf Hobbies steel battery tray I don't need to add any weight to my car when using the Orion 4800 and Orion 5000 packs. When I use my SMC 4100 pack I still need to add about 45 grams of weight. It depends on what batteries you will be using and if you have a weighted battery tray or not.
#2524
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
I think that piece was on T2 009. Since this car is very expensive, they must try to make it look worthwhile
I'm also looking at one of these new JR servos. Very similiar in performance of the 9551 but JR's version is the 9411. I had alot of success with JR servos in the past.
http://www.horizonhobby.com/Products...dID=JRPSDS9411
#2526
Is the 2 speed also from the TF2? or from another car??
cheers Roy
cheers Roy
#2528
My steering is smooth so to be honest I have no reason to change my servo from the stock postioning.
Tonight I'm going to make some different size swwaybars since they are so easy to do. I can actually buy any brand with the sizes I want and then use my Dremel and cut them to length. The E4 has the best swaybar setup of any touring car I have used. Simple and easy to make different sizes.
#2530
My servo is mounted in the standard postion with Yeah Racing aluminum servo mounts. Mounts are only 7 dollars and look they where made for this car, especially if I polished them then they would look total factory.
Anyone knows where can i buy firmer sway bars for the E4RS2009 ?, usually im a no-bar racer, but i noted and felt the bar effect on my E4, im not using the front, only rear, and its great, but th bar effect its too soft and i want to try a firmer one,
thanks,
Pato Concha
Southamerica
#2531
Hi guys, i need a little help here ...
Last race where i debuted with the E4 and got 4th place, we used this layout :
Now, this weekend i have another race on same track, but the new layout its :
Last race, i used 3.68 FDR on 13.5 brushless and it was almost perfect, good low end power and enough speed on the straight to be on par with 95% of the fastest guys.
Now, for this new layout you would use the same ?, or would be good to test some different ?, maybe a little higher FDR as this layout does not have long straight sections ? (right now im on 38T Pinion + 68T spur, maybe going to 70T spur would be better ?).
thanks in advance, all opiniones welcome !!
cya,
Pato Concha
Southamerica
cya,
Pato Concha
Southamerica
#2532
thanks,
Pato Concha
Southamerica
thanks,
Pato Concha
Southamerica
SHould take me about 5 minutes to make my sways. Just need to go to my local shop and buy the wire to make them.
#2533
Has anyone checked their rear toe in on one of the numberous gauges on the market? I have the arrows both going out in the rear that should give me the most rear toe in at 2.5 on my E4FS and the gauges are only showing about 1 degree rear toe in. Front both arrows are pointing in so I should have 1.5mm of front arm sweep.
2nd question is I just looked at the car and looking to raise my roll centers in the front 1mm. I see the front a arm mount attaches to the bulkhead but it looks like it has a 2ns screw hole in it as if I do use 1mm spacers I would use the 2nd set of holes (at least on the front). Not sure since I never took the car fully apart yet and the directions are not clear on that part.
#2534
cya,
Pato Concha
Southamerica
cya,
Pato Concha
Southamerica
#2535
For starters stay with present FDR and see how it works out.
As i think the track now is,is that you have 2 shorter straights instead of one longer straight.
You still have the same sort of infield so try what you have now and if you lack a bit of top speed you can go a teeth or 2 up on the motor pinion.
cheers Roy
cheers Roy
cya,
Pato Concha
Southamerica
cya,
Pato Concha
Southamerica
