Old 08-05-2009, 10:20 AM   #2326
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by John St.Amant View Post
I hadn't thought about it but anythings a possibility.
I've not been traveling much lately BUT...
I hope all my updating is done before then.
Depending where your at in MI it would be a I guess a 10 hour ride or so. Last time I was up your way I was about 10 years old and we went to visit my uncle in Flint. I think it took as roughly 9 hours or so from Harrisburg PA area. Harrisburg is roughly 1 hour from Frederick MD.
ST Racing Concepts (STRC)
Old 08-05-2009, 02:59 PM   #2327
wyd
Tech Legend
wyd's Avatar
Ok its time to post about the E4FS rubber setup car with the one way that I just received. I traded a friend of mine for it. Car is brand new and never been run (just built). Now I read almost every page on this forum and not sure about all the other cars but mine is bone stock out of the box. I checked out the Wolf site and everything matches up with the E4FS with the One Way setup that is listed for rubber racing and has the 2.0588 reduction.
Ok It took me all but 2 minutes to figure out how to fit the DUO brushless motor in this car. I did put in the Tekin and will lightly sand the back of the chassis at the endbell on a bevel so the motor will fit perfectly and will make it better for the DUO motors as well. Still very minimal sanding needed and will be a 5 minute job to make look factory. The best thing so far is when I put the wheels on this car it is so free compared to my TC5 and some of my other 2 belt touring cars and this is will stock belts and the bears not being cleaned out at all.
After going over this car for just 10 minutes I very confident that it will work great for me. I did notice with the stock springs and oil it is a little bit too soft of a setup but not a big deal. Just super happy with what I see so far.
I looked at the car before I traded for it and didn't notice half the stuff that I did since it is mine. Can't wait to get it on the track in the next week or two.
Old 08-05-2009, 07:35 PM   #2328
The Teacher's Avatar
Trader Rating: 49 (100%+)
Sounds like the guy who built that car was a pro...
The Teacher is offline   Reply With Quote
Old 08-05-2009, 08:02 PM   #2329
wyd
Tech Legend
wyd's Avatar
He did a great job.
Old 08-06-2009, 05:58 AM   #2330
jdm19turn's Avatar
[QUOT
E=wyd;6167135]He did a great job.[/QUOTE]
Hi Wesley r u racing at hobby town this month for the ctcs race ? Long time no see later joey
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 08-06-2009, 06:20 AM   #2331
wyd
Tech Legend
wyd's Avatar
Originally Posted by jdm19turn View Post
[QUOT
Hi Wesley r u racing at hobby town this month for the ctcs race ? Long time no see later joey[/QUOTE]Not sure if you mean me but if so I'm not Wesley.
Old 08-06-2009, 09:58 AM   #2332
jdm19turn's Avatar
Not sure if you mean me but if so I'm not Wesley.[/QUOTE]
Sorry bud my bad
mi4 ,mi5
Old 08-08-2009, 10:26 AM   #2333
wyd
Tech Legend
wyd's Avatar
Well my E4FS is getting closer to getting ready to run. I have not been in too much of a hurry as I want to make things right from the start. I been messing with the battery fit and have it down to the battery I want to run so I now I have that problem solved. Pretty much any pack that is 20mm to 23.5mm thick will fit. With the 2mm toplate raised 23.5mm thick battery for is the thickest I want to go.
The only other thing is when using the DUO motor for sure my amount of motor movement is small as the motor hits the brace that the side belt tensioner is on. I have many different spur gears and pinion gears so a little bit of a pain but still not a problem.
I did hook up the speedo and run some runs testing out the nes speedo and new programming. Everything is smooth and the belts are smooth with no skipping under hard accelerations and then smacking the brakes and then hard throttle with no problems. Will see when I hit the track if it stays like that but shouldn't be a problem with the excellent belt tensioners that are included in the kit.
Old 08-10-2009, 09:51 AM   #2334
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys,
Finally i received my E4RS2009. I still dont open the box as im with too much work.
I need your help on a base setup for :
- Asphalt Outdoor.
- Rubber.
- Clean track with little dust on the outside areas.
- Little bumpy on some sections.
- Just a little technical on the infield with a 195 feet back straight.
Im using Novak GTB Speed + Novak 13.5 SS PRO Brushless motor on NiMH Batteries (no lipo allowed until January 2010).
On the setup tips please include info on FDR for the car, i will switch to 48P spur and pinion as i have many 48P material laying around and no source of 64P locally.
I will only have chance to practice on Saturday and will have my first race with the car on sunday lol !!. Las race i used a Hotbodies Cyclone with 3.91 FDR and i won the race, help me to be close to that lol !! (here we race 8 minutes each heat and finals).
thanks a lot guys,
Pato Concha
Southamerica
Tabushi is offline   Reply With Quote
Old 08-10-2009, 10:28 AM   #2335
wyd
Tech Legend
wyd's Avatar
If I have a chance tonight I will post some pics of my new E4FS. I have some stuff from Wolf on the way so I think my first time on the track might be possibly Thursday or Saturday. Will see how it goes.
Old 08-10-2009, 10:40 AM   #2336
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Yes ... I should have a new side belt tensioner and upper deck mount here soon.
Direct from the Wolf Man
Pro-Line Racing , Boca Bearings , Competition Heat.
Team Durango DEX210, DEX410V3, DESC410R, DNX408
Futaba FAAST 2.4 4PkS, LRP, Tekin, Xcellorin
John St.Amant is offline   Reply With Quote
Old 08-10-2009, 10:59 AM   #2337
wyd
Tech Legend
wyd's Avatar
He did mention about the new tensioner so I might call him and place one on order so when it has then I can get it right away.
Was looking at the new Novak Ballistic for 17.5 and possibly 13.5 because the way the endbell is it looks like a great fit for the E4 cars and since it is so tapered at the the end I bet you can get full throw on motor movement. What do you think?
Do you have the Wolf battery tray? I ordered one of those and he was saying I can gain a little more room with his tray for the batteries. If thats the case it would be great because my Yeah Racing 5K pack fits but with the stock platic tray I can't get the tray fully closed even with the topdeck raised 2mm. The way it mounts in the front makes you raise the pack some at an angle to get it in and this is part of my problem. Not a huge deal because I know of many other packs that will fit so I will just buy one since they last so long.
Old 08-10-2009, 11:39 AM   #2338
wyd
Tech Legend
wyd's Avatar
Originally Posted by Tabushi View Post
Guys,
- Asphalt Outdoor.
- Rubber.
thanks a lot guys,
Pato Concha
Southamerica
Try here. Plenty of setups to choose from.
http://www.petitrc.com/reglages/team...amMagicE4.html
Old 08-10-2009, 01:02 PM   #2339
WHATS THAT YOU SAY NOVAK IS RELEASING BALLISTIC MOTORS IN 13.5?!!!
OhhhhhhhMaaaaaaan.
Old 08-10-2009, 01:06 PM   #2340
wyd
Tech Legend
wyd's Avatar
OhhhhhhhMaaaaaaan.
10.5, 13.5 17.5 and I think 21.5 as well. Like I posted on the Ballistic thread I never ever liked Novak products but this one has me looking hard at getting one. Man saying that if you knew well is going to make hell freeze over.
I have to think they would be killer motor in the E4 for fit and maximum motor movement. That small end looks great for fitament in an E4. Black in color don't hurt either as I like black anodize.
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
