CRC 1/10 Pan Car >
CRC 1/10 Pan Car
Like Tree3Likes
CRC 1/10 Pan Car
Old 12-14-2008, 05:21 AM
  #571
heretic's Avatar
Originally Posted by Darkseid
I need a little help from the pan car experts.
I can't get my Gen X-10 to stop pulling to one side under power. I've tried everything that others have suggested, but nothings working.
I have:
-adjusted the tweak screws
-made sure the tires are all level and the same size
-made sure my rear pod is completely free
-made sure the car tracks dead straight
-loosened the diff to avoid spinning the tires
But nothing seems to work. The car always pulls to the left under power. I'm out of ideas. Even when I ran cheap Tamiya F1 pan cars on dusty parking lots back in the day, the damn cars still went straight under power, so whats the deal here???
Figuring this out is a make or break deal for me with the class. Having a car that wont go straight is no fun to race. So if anyone has any ideas how to solve this let me know.
Just in case, check the rear axle bearings . One gritty bearing can cause what you describe. Also, the play (backlash? ) in the axle,which has to be sufficient ( like 1-2 tenth of mm) of course. Good luck !
heretic is offline
Old 12-14-2008, 07:49 AM
  #572
AdrianM's Avatar
Also, make sure your rear axle is shimmed correctly so it not offset to one side or another and they your chassis is balanced left to right before you touch your tweak screws. You will need to add weight opposite your speed control to balance the car.
AdrianM is offline
Old 12-14-2008, 07:51 AM
  #573
Uneven weight balance left to right can cause that. The lighter side of the car will accelerate faster and cause it to turn. Check your balance and if its off, add a sqaure or 2 of lead to the right side of the car.
tfirsching is offline
Old 12-14-2008, 01:40 PM
  #574
espresso1967's Avatar
Trader Rating: 18 (100%+)
Picked up two of the manutech bumpers since I am on my fourth bumper and at $25 a pop, willing to try the $10 ones. Though one thing did cross my mind. If this is stronger and instead of breaking the bumper, I started breaking my chassis than it will not be worth it. Will keep everyone posted but I do not plan on crashing much now since I got the hang of the car but if someone bumps me, than that could be a problem. Running a 3.5r will definetyl test this bumper if I crash. Fingers crossed I don't cause any damage to the chassis.
Originally Posted by Still Bill
Had issues with the stock CRC Gen-X 10 bumper plate from the get go. So, I have to give Manutech a plug for their Gen-X-10 kydex bumper plate. Got it from them for only $10 plus shipping.
Have it teamed with the CRC foam bumper ($4.95). I cut back the leading edge of the kydex plate about 1/2" (following their slots) to make it so the foam bumper overhangs the plate. Now I have a soft bumper to cover my "little" mishaps.
http://www.manutech.info/rcracinghom...gproducts.html
Anyone want to buy my spare CRC bumper plates??? At least they're pretty!
espresso1967 is offline
Old 12-14-2008, 05:30 PM
  #575
Trader Rating: 16 (100%+)
Just take that Manutech bumber and cut it back to the inside edge of the provided machined slots. Then, add the CRC foam bumper and you will have plenty of front end protection.
Believe me...Mine is fully tested
Love my Gen-X 10...with lipo...
Still Bill is offline
Old 12-18-2008, 04:26 AM
  #576
s13evo's Avatar
Need help guys.
went for a first time run today and i cant full throttle the gen10 because it will just do donuts, also when braking it will also do 360's or sometimes 720' spins all the time.
maybe tighten up the Diff?
left to right weight balance is equal, maybe the front to back weight ratio can cause this spin out?
or does pan cars just normally do that with to much power. its only a 13.5 novak with 7.4 lipo.
s13evo is offline
Old 12-18-2008, 04:54 AM
  #577
Trader Rating: 14 (100%+)
Originally Posted by s13evo
Need help guys.
Check your tweak. It was discussed in detail a few post back along with a setup link. Pan cars are very sensitive to tweak.
rushrush1 is offline
Old 12-18-2008, 05:02 AM
  #578
Dasmopar's Avatar
Need help guys.
Sounds like a massive lack of traction. What surface are you running on?
Dasmopar is offline
Old 12-18-2008, 05:33 AM
  #579
s13evo's Avatar
was testing on a dusty volleyball/basketball court. well i tighten the diff real tight and will test on a real track this weekend.
s13evo is offline
Old 12-18-2008, 05:52 AM
  #580
Dasmopar's Avatar
Well that was your problem then. car didn't stand a chance on a dusty gym floor.
Dasmopar is offline
Old 12-18-2008, 06:57 AM
  #581
Need help guys.
You may want to downgrade to a 17.5 motor. Car is gawd awful fast with a 13.5 and 7.4 lipo...
Old 12-19-2008, 07:55 AM
  #582
cdee's Avatar
Breaking the chassis is certainly worse that breaking a carbon bumper, that was one of the main considerations in the design of the Kydex version. Impact zones along the front edge, proposely a little weak/thin where it bolts to the frame, and of course the selection of matieral. I am still running the original proto-type teamed up with the crc foam and after 40-50 races, have not had any issues. Thanks to everyone that is giving them a try!!
cdee is offline
Old 12-19-2008, 11:52 AM
  #583
Verndog's Avatar
13.5 w 7.4V on a dusty gym floor??
Ya...thats the problem alright.
Too much power and your driving on "ice"...very bad test combination.
Verndog is offline
Old 12-19-2008, 05:16 PM
  #584
s13evo's Avatar
ehehe yeah i didnt know it was gonna be that bad. because i usually test my TC car on that outdoor court and never experience too much slipping.
thanks guys, will try test on a real track and see if i have to downgrade to a 17.5 motor.
s13evo is offline
Old 12-19-2008, 11:11 PM
  #585
Ok clamping hub arrived just in the nick of time. I can now head on out to the track tomorrow morning. Here are some pics of my freshly painted p905b
