CRC 1/10 Pan Car
#541
Are you going to be racing world gt or just bashing? I run a big nitro track with 3.5r Novak 7.4 lipo. I originally ran 17.5r but way to slow for the track I run on and was on the verge of getting run over by 1/8th nitros. If you are going to be racing world gt follow the motor specs for your track. If just bashing and depending on your experience go with 13.5 and if it really is a big track 3.5r would be good just don't try to push it to the limit or you will have tons of pieces to pick up if you hit a hard barrier. By the way what track are you going to be running?
#542
I had a similar problem last summer. I had taken a really hard rear end hit and afterwards I couldn't get the diff to set properly. Eventually I found that the axle had a crack in it between the right pod and the pinned diff. I found it when the axle sheared in two. I don't know why that would effect the setting on the opposte side of the pinned diff but I had no more problems after I replace the axle.
Lee
#543
I'm running 12 diff. balls with a alloy nut. I also added about 4 axle shims and now I can set the diff the way I want it. I put the shims between the outer bearing and the red alum. spacer. Seems to works good for me.
#545
#546
#547
Try running this instead of the shims, smooooooth.
http://www3.towerhobbies.com/cgi-bin...?&I=LXFKL0&P=7
#548
Yes they are the same as the shims you use between the bearing and the hub on the other side of the axle.
I'm using the light weight diff rings and ceramic Cefx balls and it is silky smooth so far. The thrust bearing looks like a good idea but has a 4mm I.D. and looks to weight about 40lbs. lol
#549
Regional Moderator
I need a little help from the pan car experts.
I can't get my Gen X-10 to stop pulling to one side under power. I've tried everything that others have suggested, but nothings working.
I have:
-adjusted the tweak screws
-made sure the tires are all level and the same size
-made sure my rear pod is completely free
-made sure the car tracks dead straight
-loosened the diff to avoid spinning the tires
But nothing seems to work. The car always pulls to the left under power. I'm out of ideas. Even when I ran cheap Tamiya F1 pan cars on dusty parking lots back in the day, the damn cars still went straight under power, so whats the deal here???
Figuring this out is a make or break deal for me with the class. Having a car that wont go straight is no fun to race. So if anyone has any ideas how to solve this let me know.
I have:
#550
Shawn.
#551
I have:
I have:
#553
I have:
I have:
#554
http://www.slapmastertools.com/110-1...st-bearing.php
#555
Slapmaster is the cat's meow!
