CRC 1/10 Pan Car
#721
Could someone please tell me the diameter of the balls used for the side links on the Gen X 10?
Is it the same as that of normal ball studs?
What is the part number?
(it's for solving a little problem on another car)
#722
glue on side wall of tires
I am new to pan cars, just learning from reading this thread and I didn't even get my car on the track, still new.
Why you guys glue the side walls of the tires?
Do I really have to trim them before using?
I have bought 2 pairs of front and 2 pairs of rear tires from CRC, they are 60mm if I am not wrong is there any problem running them like this?
#723
spur (original from the kit) 100T
pinion: 26T
Tire diameter: 61mm
Calculating I got:
61*3.14*26/100=49.8 correct?I have to divide everything by the spur?ok?
Now my idea is to run on asphalt, 4.0 LRP motor, Orion 3800 Lipo, Futaba 9650 and Sphere TC speedo, with this roll out I will be fine?
I now understand the idea of how calculating it, but I did not understand how to apply it.
Really sorry to answer so many questions that might be stupid but as I told I have never been to pan cars before.
#726
Hi
on my Windows Live page you can find a rollout chart for pro10 for both 64 pitch and 48 pitch gearing.
http://mcc-konstanz.spaces.live.com/
#727
TYRE(TIRE) Trueing
Hi
I have just got my gen 10 loads of info found on this site but i'm running jaco world spec wheels 64mm out of the box loads of grip roll so is there anyone out there ( i'm in the uk)that could true my tyres down to 60mm will post out and pay for the work
thanks in advance
otherwise is there a 10th pan arbor out there
thanks in advance
#728
Hi
thanks in advance
thanks in advance
Just send them to me with about $20 (US) so I can return them...LOL
Seriously, you need to cut the rears to about 57mm to get the ride height down. For carpet, I start with 55mm fronts and 57mm rears. For outdoor, I can start with 56mm/58mm.
I know...It's a lot of rubber into the trash...But, the performance is top shelf.
If you end up with a bit too much traction with the Jacos, try the CRC tyres. They are a bit firmer with their slightly larger wheels.
Cheers!
Bill
#729
balancing the gen 10
To balance the car i placed the car on a pointed spacer it tipped to the left looking from the rear i then fitted around 60g of weights on the right side until the car stays central on the points just this sound about right
hopefully this will sort my car pulling under power
#730
#731
Rubber tires
Hello guys,
Looking at a website here in Brazil for EP cars I found the link for a german one, specialized on pan cars.
There I found on a thread that there is adptor for pan cars to use the common ruber tires, have you ever seem something like that?
I am asking because here in Brazil pan cars are not popular, so everything I have to buy from amain, stormer, rcmart, mushroom and so on and starts to became expensive.
If someone have ever seem or know where to buy it, please PM me with the details.
http://www.moosi-masters.de/forum/download.php?id=1324
#733
#734
