CRC 1/10 Pan Car >
CRC 1/10 Pan Car
Like Tree3Likes
CRC 1/10 Pan Car
Old 03-03-2014, 10:19 PM
  #3661
How is track width adjusted with the SE kit? I see two sets of arm mounting holes to move the arms either forward or back for two wheelbase positions but I don't see any holes to move the arms in and out for width. Am I supposed to just shim the wheels?
rossb is offline
Old 03-03-2014, 11:00 PM
  #3662
Trader Rating: 16 (100%+)
The #17403 Rev. Servo FE Plate: GX10-Wide should fill the need to have the wider track at the front. It was originally developed for the LE chassis; but, is fully functional on the SE chassis.
For the SE, you have the option of dremeling off the tabs that are no longer needed with the narrower chassis plate.
The wide plate is great at a major event where traction goes off the scale. But, I would like to see a middle width FE plate at some point in time.
Bill
Still Bill is offline
Old 03-03-2014, 11:11 PM
  #3663
Thanks Bill. Sounds like I would need an option part to adjust the track width with my SE.
rossb is offline
Old 03-04-2014, 08:39 PM
  #3664
You can shim several thousandths (before securing the wheel with the locknut on the axle threads); but, to go from standard to full width is about a 1/4" change overall (1/8"± on each side).
The wide plate does provide stability; but, you also give up a certain amount of steering response with it. Probably not an issue when traction is high. I only find it necessary to use the wide plate at a major carpet event when traction tends to get way up there. Currently have the narrower plate in all three of my WGT cars; and, the wide plate at the ready in my pit box.
Forgot to say that I routinely have to trim the front wheel wells a tad more for wheel clearance with the wide plate.
Bill
Old 03-04-2014, 08:57 PM
  #3665
Odin544's Avatar
Trader Rating: 93 (100%+)
What do the different front ends do? I see there is a 1/10th and 1/12 front ends. Plus narrow, standard and long arms. So many options! Makes me think TC is simple haha. I guess I'm just more familiar with TC's.
Odin544 is offline
Old 03-05-2014, 07:39 PM
  #3666
And I was a TC guy too. TC options are way more complicated in my book. My Losi, Corally and Xray TC cars had far more expensive options than these WGT pan cars. My spare/replacement parts racing budget ($) was instantly cut to less than half when I went over to CRC pan cars. Because TC rubber tires had some serious issues at the time, the fun factor for me went way up with foam tires.
1/10th and 1/12th front ends only refers to the lengths of the king pins and related springs used on both sides. On a smooth fast carpet track I normally use the 1/12th setup. For asphalt, it is always the 1/10th versions. You can get the most used king pin and spring options for maybe $25.
A standard width FE plate comes with the kit and the #17403 wide reversed servo FE plate lists ($16 list).
With the #3348 long dual-mount upper arms ($4 list) you need a #3277 graphite cross brace ($15 list) (which is actually made for a 1/12th scale; but, is easily modified for use on your WGT car).
That's all of $60 for the above options; plus, add a #1776 adjustable brace ($17 list) for pretty much every option I use on my LE/SE's.
There were individual option parts for my TCs that easily cost more than that...LOL
Cheers!
Bill
Old 03-09-2014, 06:13 AM
  #3667
I used the short ball cups on the shock of my new SE kit and I have excessive droop with no apparent way to shorten it. Are you guys using shock limiters (like fuel tubing) to limit droop?
Edit - I used a small section of fuel tube as an internal limiter and fine tuned the droop with the ball cup position and I got the droop I wanted.
rossb is offline
Old 03-09-2014, 02:18 PM
  #3668
All three of my WGTs have one o-ring inside the shock to limit the travel.
I believe the shock comes with an extra o-ring for this purpose.
Bill
Old 03-09-2014, 04:38 PM
  #3669
I tried putting the extra o-ring in the shock and I still had about 3mm of droop with the ball cup screwed in all the way.
rossb is offline
Old 03-10-2014, 05:54 PM
  #3670
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
What the difference between these 2 springs?
http://www.tqrcracing.com/shop/produ....asp?p_id=1039
http://www.tqrcracing.com/shop/produ....asp?p_id=6877
I see they are both purple. But are they same rating? I know CRC had to switch spring makers And the new one is CLN3411. Reason why I am asking is that I have the older one CLN32995. I was going to use with that SG1 guy set up that everyone is using. But I wasn't sure if he was using the old one or new one. Can someone shine some light on this. I have some of the older springs and just want to know if there is a difference.
FL_SilverEvo8 is offline
Old 03-10-2014, 11:43 PM
  #3671
http://www.slapmastertools.com/spring-chart.php
InspGadgt is offline
Old 03-12-2014, 04:07 AM
  #3672
Originally Posted by InspGadgt
Is that the only for the center spring or is that for the side springs also? and is that 80% post to be the spring rating?
Old 03-12-2014, 09:24 AM
  #3673
That chart is for the center springs only.
Per Brian Bodine (Slapmaster), get the new CRC center/side springs to be current with setups from team drivers.
Check Slapmaster posts for his take on the new springs.
Bill
Old 03-14-2014, 06:24 AM
  #3674
Bill
Is his take on it on here or that web site that posted earlier
Old 03-14-2014, 06:31 AM
  #3675
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hey Guys,
I found a few old pics of my LE car for a reference back to what I ran
CRC 1/10 Pan Car-wgt2.jpg
CRC 1/10 Pan Car-wgt.jpg
Since then I have upgraded to the SE kit.
My set up is not the same for that car.
I'll get some pics up of that car and set up for those of you who have switched to it so we can compare set ups
sg1 is offline
