Tamiya mini cooper
that is just the coolest mini i've ever seen. gotta get me one of them! i'm guessing the usual jap shops will have them
No I know what to shop for...
Oh!
are they any good on asphalt?
Thanks!
There are lots of tires out there now that are great on asphalt. The HPI's have been somewhat surpassed these days. Still a good tire, but there's better around. Perhaps ask some people at your local track what they use?
As for wheels, the Tamiya flouro swift wheels are hard to beat in terms of value for money. Tough, bright, and cheap. US$5 for 4 wheels.
I can pretty much guarantee that Tim put those wheels on because he's only just got them in stock now (http://www.m-chassis.com) and was showing them off!
The X patterns? Probably because they look good.
[QUOTE=rcnutbag;8243364] Perhaps ask some people at your local track what they use?QUOTE]
oh!, there is noone to ask, I am one of 2!! people running the mini... We do hope more people will see the light! it is easy and no too expensive.
I found the kit tires/rims to be OK on our track...
I think I will try some racing slicks from Rcmart next time. they come premounted and well not to expensive.
Thanks!
Thanks!
Thanks!
Thanks!
slick tires
ABC Hobby tires are pretty grippy on all surfaces, including carpet, and does not wear out fast. You will have to use preferred tire sauce for carpet use.
the xpress mini tires are pretty good for me and cheap.
Yes RCmart will have pretty much any tire you would need. Most tires have different hardnesses available. For example ride tires are sold as soft, medium and hard (click). Normally you would use soft when the weather is cold or there is little traction on the track. Conversely, hard would be used in warmer/hot weather or very high traction tracks. Similarly, some manufacturers put a number with the tire that roughly suggests at what track temperature they would work best (click). I hope this helps a bit.
Very nice sir, looking forward to hearing the full story already.
I just got my M-05 kit in the mail and I was reading the manual. At some parts is shows different steps for M0-5 M, L and S..
Just wondering which one I'm supposed to build??
Also, does anyone happen to have a link for bearing replacement sets? For all 12 of the plastic BA18 and 6 of the BA19+BA20
Anything helps
Thanks.
Anything helps
Thanks.
Anything helps
Thanks.
Anything helps
Thanks.
Bearings: http://www.rcmart.com/catalog/rc-tam...s-p-29027.html
It depends what wheelbase you want to build, you follow a specific one. What body does it come with? That pretty much determine your wheelbase.
The body looks like an old model mini cooper I think..
Don't know what it's called exactly
