Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-20-2011, 05:11 PM
  #15151
oldnwise's Avatar
Originally Posted by Shangrila
What's the best way to clean the AW grease off the gear(s)?
Huggies Baby Wipes. Cleans up almost anything.
oldnwise is offline
Old 06-20-2011, 05:15 PM
  #15152
I)arkness's Avatar
personally experience with AW greas over the gears, i would just get some new gears. that is unless you dont mind scrubbing them with a toothbrush and degreaser
I)arkness is offline
Old 06-20-2011, 05:17 PM
  #15153
hairy's Avatar
Brake cleaner or "simple green"
hairy is offline
Old 06-21-2011, 02:00 PM
  #15154
tony gray's Avatar
Originally Posted by Fluffy622
Hey guys! Ive been racing my M05 inside my local hobby shop on there new carpet track for a couple months now and am loving it. I was wondering what your ride heights are? Mine is close to 12mm. I have a stock M05, and there are no shock adjustment holes and i cant figure out how to lower it. I would appreciate any help I can get. Thanks
Fluffy, you need to get that sucker down a LOT more. We're talking in the region of 5-6 mm, so half what you're currently running. It'll transform your car.
I'm not sure how you can do it if you're running the bog standard M05 friction shocks as there's no easy way to do it with them.
You're gonna need to change shocks I'm afraid (unless someone else knows any better way?)
tony gray is offline
Old 06-21-2011, 05:23 PM
  #15155
gruman28's Avatar
Trader Rating: 18 (100%+)
Anyone using those black gears on there cooper? I ordered a set because I was curious.. Wondering if they will last longer?
Chris
gruman28 is offline
Old 06-21-2011, 07:15 PM
  #15156
Fluffy622's Avatar
Hey Tony. I have the oil filled shocks on my M05. I was talkin about how there isnt any shock tower adjustment holes for lower or higher ride height. Any ideas? Thanks
Fluffy622 is offline
Old 06-21-2011, 07:22 PM
  #15157
tony gray's Avatar
You dont use shock tower adjustments to change ride height.
Read THIS (about halfway down) to show you how to change your shock length to drop the car down.
Old 06-21-2011, 10:23 PM
  #15158
caltek1's Avatar
Trader Rating: 38 (100%+)
gruman28,
The Tamiya reinforced gear set works the same as the originals. Just black and should last longer. I have these fitted to my car and seems no different to me, they still have the same gear noise, even when using a little spray of silicon lube on them.
Later,
Calvin.
caltek1 is offline
Old 06-21-2011, 10:51 PM
  #15159
Fluffy622's Avatar
Wow very cool! I was wondering what those little spacers were for lol. That's a really cool and informative web site. Thanks for the help!
Old 06-22-2011, 06:35 AM
  #15160
gruman28's Avatar
Thanks. I ordered a set of both. Does anyone know where I can order a set of spline outdrive cups? The ones that go through the diff (guess thats what they are called). I have a few different diffs I use and they all have the old splines on them. Mine are wore out.
Chris
gruman28 is offline
Old 06-22-2011, 06:53 AM
  #15161
Tim K's Avatar
Chris
Were you after standard (9805368) or hardened (53218) ?
Tim K is offline
Old 06-23-2011, 08:56 PM
  #15162
Fluffy622's Avatar
Does anybody know the part number for the Tamiya M05 adjustable camber links? I cant find them on tower hobbies
Old 06-23-2011, 11:39 PM
  #15163
caltek1's Avatar
Find attached a Link to Tamiya USA website for Hopups for the MO5. I believe google can be your best friend.
http://www.tamiyausa.com/product/rcp...=desc&offset=1
In response to your question PNo 54182. Check link above for accuracy.
Regards,
Calvin.
caltek1 is offline
Old 06-24-2011, 08:24 AM
  #15164
Make your own-----much,much cheaper. All they are is a 3x12 mm set screw with 5mm adjuster ends.
Granpa is offline
Old 06-24-2011, 09:04 AM
  #15165
Fluffy622's Avatar
Thanks Guys!
