Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-20-2010, 05:28 PM
  #13636
Madulla's Avatar
Default TA03 Outdrives
The TA03 Diff comes all together with everything that you need to make it work. Put it together and put it in.
Anyone know the part# for the TA03 outdrives? Mine are wearing out.
Madulla is offline
Old 11-20-2010, 09:41 PM
  #13637
RCD211's Avatar
Ok so from what I have read in this great thread the following things are recommended for a good setup for racing a m05 pro
TA03 ball diff.
2 or 3 degree rear hubs for more toe out? To prevent it from wandering at high speed.
I think the m05 Pro covers the most but also TRF shocks?
Cheers Rhys
RCD211 is offline
Old 11-21-2010, 02:12 AM
  #13638
mangoman's Avatar
Rear hubs can be handy, note they are toe in.
Personally, to limit the wander i have found that you put a fair amount of toe out on the front (not the rear).
mangoman is offline
Old 11-21-2010, 11:41 AM
  #13639
Your right about the front... in fact the instruction manual even says to make sure you have some toe out in the front.
Jay
pyro18t is offline
Old 11-21-2010, 12:07 PM
  #13640
scribbler's Avatar
What I found is if you have a minor amount of toe in it makes the steering more responsive, even a little twitchy.. Two degree toe in rear hubs seem to work better for stability. If you have your car setup with a minor amount of toe out it typically takes steering out of the car, and decreases turn in. This is true in a M05. M03's are the opposite
scribbler is offline
Old 11-21-2010, 12:08 PM
  #13641
tony gray's Avatar
This might well just be the Ultimate FWD Mini kit.
The CF-R M05 conversion from Tech Racing.
We've built it, we've driven it and the full story will be up in a few days. In the meantime, here's some pics to whet your appetite.
tony gray is offline
Old 11-21-2010, 12:15 PM
  #13642
gtfour93's Avatar
Trader Rating: 22 (100%+)
Looks nice, especially the battery setup.
gtfour93 is offline
Old 11-21-2010, 12:17 PM
  #13643
Trader Rating: 77 (100%+)
where and whene can i buy one?
artoftatt2 is offline
Old 11-21-2010, 12:19 PM
  #13644
Man imagine how light that thing is going to be without all that extra plastic! Too bad my track folows TCS rules!
Jay
pyro18t is offline
Old 11-21-2010, 02:11 PM
  #13645
tudor_47's Avatar
What are the wheels??
tudor_47 is offline
Old 11-21-2010, 02:21 PM
  #13646
caltek1's Avatar
Trader Rating: 38 (100%+)
"What are the wheels??"
HPI X patterns, (PNo 4565) on mini rims.
caltek1 is offline
Old 11-21-2010, 02:33 PM
  #13647
gtfour93's Avatar
Did Tamiya release gunmetal mini wheels? What's the item number?
gtfour93 is offline
Old 11-21-2010, 03:57 PM
  #13648
They're Tamiya 84158 rims.
RCmart has them: click
rcnutbag is offline
Old 11-21-2010, 04:21 PM
  #13649
gtfour93's Avatar
thanks!
gtfour93 is offline
Old 11-21-2010, 05:03 PM
  #13650
caltek1's Avatar
TFG,
Thanks for whetting everyones appetite, so where did Tim run the car??? Another mini to purchase.
Later,
Calvin.
caltek1 is offline
