Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-18-2010, 04:12 AM
  #11881
Peter $'s Avatar
Originally Posted by tudor_47
Yes that is correct.
Thanks!
Now I know where to go on my way home from work (LHS)
Cheers,
Peter
Peter $ is offline
Old 03-18-2010, 04:57 AM
  #11882
Originally Posted by PaPeRo
You are using 2.4mm balls correct?
Think so
They were just a loose bagin my spares box that fitted
sidecarphil1 is offline
Old 03-18-2010, 08:33 AM
  #11883
We have just started a mini class locally, and most of us are buying the M05.
some the PRO kit, some the basic kit
What are the best upgrades for the kits to be durable, and competitive.
We are running the TCS rules.
Bodywerx_rc is offline
Old 03-18-2010, 01:12 PM
  #11884
over gear's Avatar
Trader Rating: 18 (100%+)
which lipo do you guys run on the M05?
over gear is offline
Old 03-18-2010, 01:17 PM
  #11885
it was a standard M05 mini
till i went to town on it
and now it goes like a train quick reliable and fun to drive
i dont thnk there is much more i can buy for it now
Old 03-18-2010, 01:24 PM
  #11886
Starteur's Avatar
You have PM..
Starteur is offline
Old 03-18-2010, 07:43 PM
  #11887
Originally Posted by Starteur
You have PM..
Don't see one.
Old 03-19-2010, 04:14 AM
  #11888
Starteur's Avatar
It's OK man, I got the infos about your track on a french forum!
thanks anyway,
Best regards
Starteur is offline
Old 03-19-2010, 07:23 PM
  #11889
I ordered a HPI Datsun 510 body and need to get some wheels/tires so I have a few questions.
1. Are the HPI wheels that come on their cup racers strong? I like the ones that come on the 510. What offset should I get? They come in 0, 3, and 6.
2. I like the way the 60D radials (50683) work on carpet but can't find them in stock anywhere. How do they compare to the 60D super grip radial tire (53254)?
3. Are there any other tires I should consider for carpet racing? We have a rather long straight so the larger diameter tires make a big difference.
Andy
woodys3b is offline
Old 03-20-2010, 11:12 AM
  #11890
Trader Rating: 29 (100%+)
With all the discussion going on about ball diffs, I thought I would add a little info discovered in building my m05. I recently bought the Tamiya 54194 m05 ball diff, appearantly this is a new part offered by Tamiya. This one is built with aluminum outdrives already dialed to accept, and includes the 416 blades and thrust bearing. I did change the diff screw to the 416($5) one due to the kit T nut being plastic vs. the 416 metal one. The only modification needed was on the screw side of the diff, I had to add a short piece of fuel tubing to keep the dogbone in the outer axle. This setup is really nice, adjustable with the removal of the upper link like any TC and it is still TCS legal.
**I forgot to mention the included Tamiya TUE-104BK esc has low voltage cutoff for lipos.
JustMe2 is offline
Old 03-20-2010, 06:27 PM
  #11891
PaPeRo's Avatar
For those of you planning on using the 3Racing ball diff, there are actually two models and two versions. One model is made of aluminum and the other is made of steel. For both models the new version 2 comes with blade protectors.
PaPeRo is offline
Old 03-20-2010, 09:05 PM
  #11892
Trader Rating: 118 (100%+)
Thumbs up
for you Tamiya Mini nuts!
http://www.rctech.net/forum/r-c-item...m-painted.html
Chris Furman is offline
Old 03-21-2010, 02:10 AM
  #11893
Hi, just sharing. A large Corporation recently held their Employees Day celebration, and one of the featured events was a Tamiya Mini RC race. It was a fun day and exposed the hobby to thousands of people, especially kids throughout the entire day.
Front view of the track... yes those are robots. They did the marshalling
The drivers stand was cramped with spectators. It was fun and a challenge to drive when you have kids squeezing under your legs during the race in order to get a better view of the racing action.
Writeup, photos and video of the Tamiya mini race.
Hopefully more corporations do this. Thanks for reading.
rccartips is offline
Old 03-21-2010, 02:45 AM
  #11894
danjoy25's Avatar
Trader Rating: 38 (100%+)
Here's some pics of whats mostly available.
danjoy25 is offline
Old 03-21-2010, 06:20 AM
  #11895
Trader Rating: 8 (90%+)
the manual does not mention lipo cutoff but LiFE cutoff ...
TenzoR is offline
