Tamiya mini cooper
R/C Tech Elite Member
Droop is probably minimal as dampers are built to about 55mm. Toe is also becoming more minimal - maybe 1-2 degrees out at ride height. Current damper setup is 3 hole pistons, 20wt Trinity, short reds front, short blue rear, w. hard sway bar.
EDIT...sorry, were you asking me? I assumed.
I know don't who you are and I don't care..I thought he maybe he has forgot about the droop..the question was referring to him NOT you..
Down Franko, DOWN BOY!
[QUOTE=back9monsta;12493675]Motor: handout Silver can
ESC: LRP QC3
Batt: IP 4200 60c
Servo: Futaba 9551
Radio: Airtronics M12
Body: Lt Wt Suzuki Swift
FRONT
I used TRF touring car shocks and put mini shock shafts with plastic damper retainer
56 mm shock length
Losi 60 wt Oil
3 hole piston
1mm of rebound
Short Black/Red spring
RIDE HEIGHT: 5mm
- I measure just behind the front arms.
I did check camber as it has fixed camber links since the ride ht. is at 5mm
Alum upright position 2, inner most hole
- To me this gave me more responsive steering
- Plastic 6mm wheel hub
Thanks Posting your set up Bensie. You are too kind. I wish I can offer advice on carpet set ups for the worlds to return the favor. But I can pray for you to win it
Danny R
ESC: LRP QC3
Batt: IP 4200 60c
Servo: Futaba 9551
FRONT
56 mm shock length
Losi 60 wt Oil
3 hole piston
1mm of rebound
RIDE HEIGHT: 5mm
Danny R
Hey Granpa, where did you finish up at Nat's? I gotta get down there and run with you guys next year!
Toe and Droop
Toe: +.5 degrees, hard to say as I eyeball it.
Droop: I actually don't measure. I usually just build my shocks 55.5mm for carpet and 56mm for asphalt and lengthen or shorten from there.
Hi Jesses I'm Okay
You know what ?
I never thought about going to TCS national ... I live in Japan and vacation there many times.. and raced there as well....
Just maybe next year ,I might give a try...
You know what ?
Grandpa- Franko(Ova) not really a butthead, he just plays one here on RCTech.
Jesse and Franko, you both need to go down next year. Great to put faces to the screen names here and good to see old friends. Plus you get to play with toy cars for a week. Worst case you get a trip to Japan out of it.
guys,
can i use Futaba servo BLS651 on a Mini?
Thanks in advance...
Qualified 7th, finished 7th. I was satisfied with those placings considering circumstances. Old age, bad eyesight, bad driving, dumb mistakes, collisions, wipe outs among others. All in all, not a bad Nats for me and a lot of fun.
Really doesn't matter whether he is or not. I shouldn't joke with people I don't know. You never know who's going to take offense. My fault entirely. I apologized, so hope that assuages his feelings.
don't worry Grandpa I got over it..
.Mini is on...:
