Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-23-2009, 05:17 PM
  #10576
cannon's Avatar
Trader Rating: 35 (100%+)
The design is the same as a Tamiya 416 spool.
That way when the spool wears you only need to replace the black plastic drive cups instead of the whole spool
cannon is offline
Old 10-23-2009, 11:15 PM
  #10577
anyone running on carpet tracks, if so wats the tire setup?
keenspeed94 is offline
Old 10-24-2009, 11:03 AM
  #10578
ok
i have bitten the M05 bug
it will replace my old and aging m03
i have bought one , the mini , with some TRF dampers and springs , adjustable upper arms , bearings , ball diff , propper drive shafts ,
what i need to know is what is a good base set up so it drives like my old M03 , as described on Mini RC as an old pair of slippers
my old faithfull m03 will be kept for keep sakes and retire with grace after winning me so many trophies and cups
any ideas guys
sidecarphil1 is offline
Old 10-24-2009, 11:50 PM
  #10579
R/C Tech Elite Member
monkeyracing's Avatar
I'm having some problems, again, the the ball diff in my mini. Even though I have it cranked down pretty tight it's slipping badly. I can actually hold both front wheels and have someone else apply the throttle and there is hardly any torque being making it to the wheels. You can hear the motor and gears spin up real good, though.
Any thoughts on how to make this problem go away? I'm on my third ball diff in the past year and a half. The gear diff is looking real good right now.
Well, there are a couple of things you can do to get it close. Run the same tire combination as you did before, but run harder springs on the rear than you do on the front. If that's not working for you, run the same springs all around. Start with medium and go from there.
Add some weight to the nose I tacked 2 ounces of lead to the front of my M-05 tonight and got that old familiar feeling back, except that it doesn't traction roll anywhere near as much as the M-03.
Other than that it's all personal setup preference.
Jim
monkeyracing is offline
Old 10-25-2009, 06:16 PM
  #10580
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Originally Posted by RC MARKET
M05 Spool
will this fit on ta03s? m03,m04, and m05 are using ta03 ball diff...
Phat-Boy is offline
Old 10-25-2009, 07:57 PM
  #10581
gtfour93's Avatar
Trader Rating: 22 (100%+)
It probably will, since they share the same TAMIYA ball diffs. This is kinda wanting me to revive both my TA03F Pro & TA03F-S.
gtfour93 is offline
Old 10-25-2009, 08:16 PM
  #10582
cannon's Avatar
I dont know the TA03 internals but it would only fit if the TA03 uses 15 x 10 bearings to support the diff.
cannon is offline
Old 10-26-2009, 01:48 AM
  #10583
Hi guys!
The first r/c I enjoied was a M01 Fiat 600 Abarth (the very first was a nitro piece of crap). I raced it in a parking lot almost 10 years ago vs touring cars with success until I joined a club and started tt racing.
Now after thinking a lot, trying to choose between m03 or m05 I ended getting a M05 Fiat 500 Abarth as a tribute of my former mini. I didnīt search for information assuming the new model should be way better and now I read thatīs way far from the reallity. Maybe the fiat will end up as a shelf queen and get a M03 but Iīm gonna give it a chance for sure.
The kit and some upgrades are coming...
mccrash59 is offline
Old 10-26-2009, 01:54 AM
  #10584
CARD's Avatar
Originally Posted by gtfour93
Thanks! I'll just have to go with a Manta Ray ball diff set then.
I think #53267 TA-03 Ball Diff is lighter in weight compare to #53070 Manta Ray Ball Diff.... Less rotating mass for faster take off.
2Ē....
CARD is offline
Old 10-26-2009, 06:15 AM
  #10585
NT
NT's Avatar
Trader Rating: 21 (100%+)
Originally Posted by mccrash59
Hi guys!
Dont sell it off just yet mate, there hasnt been enough running of the car to get a setup that works yet. Most people who are running the car are saying its pretty much on par with the 03, but isnt quite there yet. Build it and use it. Give it a few months, and setup info will start filtering through. Remember the 03 has had 10 years of racing to get to the point its at. So we'll see how the 05 goes after a bit of time.
NT is offline
Old 10-26-2009, 10:37 AM
  #10586
gtfour93's Avatar
Default M-01 Manta Ray vs. TA-03 Ball diffs
Originally Posted by CARD
I think #53267 TA-03 Ball Diff is lighter in weight compare to #53070 Manta Ray Ball Diff.... Less rotating mass for faster take off. 2Ē....
My M-01 front wheels tends to vibrate during take off at full throttle. I'm still using the original bevel gear diff setup. I was hoping that the ball diff or spool setup will eliminate that, but I know the 3R spool setup does not fit the M-01. Now are both these ball diff sets mentioned above similar in all parts? What parts are different?
gtfour93 is offline
Old 10-26-2009, 11:20 AM
  #10587
gashuffer's Avatar
Trader Rating: 48 (100%+)
I am selling my M-05. Check it out if you are interested.http://www.rctech.net/forum/r-c-item...o-version.html
gashuffer is offline
Old 10-26-2009, 12:02 PM
  #10588
SHIT !!!!
2 days too late !!!
bought a new one on saturday
Old 10-26-2009, 01:59 PM
  #10589
gashuffer's Avatar
^ Buy another for a back up I'll give you a good deal PM me. Sorry guys I don't want to go off topic.
Old 10-27-2009, 06:15 AM
  #10590
Trader Rating: 58 (100%+)
Hey Guys!! for me I have to make a rear sway-bar for my M-05 to make the car more stable at high speed turn..and now the car is more smoother even at low speed corner...here some of my car pics!!
cpi1905 is offline
