Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-22-2007, 12:33 AM
  #3076
dynoman007's Avatar
Talking hmmm
what tires do i need to win every race i enter ???????
and dont say round ones lol ..............
and also i need the mini set up for the tcs race in memphis so whoever has the crystal ball send me a set up sheet .......
dynoman007 is offline
Old 01-22-2007, 04:18 AM
  #3077
rccardr's Avatar
CArthik- Some good advice here already. S Grips are stickier in terms of compound but might be too grippy for your carpet. Hence the suggestion to use M and S combination. I would say get two pairs of each, set up one pair of each with the insert + foam combination and the other set with just the foam. On carpet you will now be ready for just about any combination of surface and shock setup possible. What you'll like is what works for you. Look at the A Main lineup of Mini's at any TCS race (regional or Nats) and you'll find that they're all somewhat different, yet all are fast.
Dynoman- Pretty much every tire combo works in Memphis due to the lovely traction they have there. I've used A's, M's and S-Grips various years and, as you know, I generally finish near the top. Same goes with shock oil and springs. I've seen everything from all whites to yellows and reds. All works.
rccardr is offline
Old 01-22-2007, 04:47 AM
  #3078
Registered User
Bodywerx's Avatar
Originally Posted by SeaKayCarthik
Whats with all the frustration? that is what I am doing, I am buying a set of A's, M's and S's. I just need to get the correct inserts now, thats why I'm asking. I dont have lots of money to glue a set of tires and notice the setup is wrong and then go and buy another set. What is wrong with asking everyone? Is that not what the forum is for? The main reason I keep asking, I cannot afford to buy tires and end up not using them like some people on the forum might be able to.
Carthik
If you are concerned about tires ask at Fastcats, if that is where you are racing.
Bodywerx is offline
Old 01-22-2007, 04:48 AM
  #3079
Registered User
Bodywerx's Avatar
Originally Posted by tamiyarcracer
Here is my take on it, seeing as it is a bolt on electronic part, I would say it is legal. But on the other hand, on a mini I see NO reason to add the weight. with the gearing in the mini, for a 5 minute race, my motor don't get hot enough to worry about a heatsinkk or a fan. if you are out playing for say a 4200 pack (30 min) then it might be useful. but then when in racing would you race 30 minutes? We ran mini's fo9r 12 hours, and no one used a fan. I think a few teams used the tamiya M03 Heatsink, just for gearbox support.
TCS Rules state Tamiya parts only, this Fan is a Tobee product. We are not talking about the M03 motor heatsink.
Bodywerx is offline
Old 01-22-2007, 08:20 AM
  #3080
Customworksking's Avatar
Trader Rating: 74 (100%+)
Talking
type As for outdoors with touring insert Hpi red or CS blue ..I will be there this year
Customworksking is offline
Old 01-22-2007, 09:55 AM
  #3081
Originally Posted by Tim K
Hey BadCarma,
These inserts are just new out:
http://www.rcmart.com/catalog/defaul...&filter_id=280
Maybe they'll work?
They sure look like they would work... it says M Car.. I could only assume that's actually for the Mini, but are there any other "M" cars? Thanks for the link, maybe I'll order a set or 3, and see if they will work.
BadCarmaNY is offline
Old 01-22-2007, 10:07 AM
  #3082
minimanintaiwan's Avatar
Hey BadCarma,
Maybe they'll work?
Car Thick, there is no such thing as a bad choice of tire or insert ... wheel perhaps (damn those white abc rims!). I run at 4 different tracks, and when one tire won't work at one track, it will work great at another, when it won't work when it's hot, then it will work when it's cold, if it won't work on the M03, then it will work on the M04 or on a 4WD mini ... just buy your tires and give the rest of us some peace ...
Hey TimK: Is the M car for M-chassis?
SPICE (#SPA-123) 5.5mm Molded )Insert (Hard) For M Car
ya damn those white ABC rims.. the black ones are great though ABC#24118
minimanintaiwan is offline
Old 01-22-2007, 10:17 AM
  #3083
tamiyarcracer's Avatar
But electronics are open!
tamiyarcracer is offline
Old 01-22-2007, 11:23 AM
  #3084
Jam-ehz's Avatar
Yeah, we've used fans with the 19T GT1 and Black-can GT2 class, no problems.. Not sure if I've ever seen one on a Mini, though..
Jam-ehz is offline
Old 01-22-2007, 11:25 AM
  #3085
Tim K's Avatar
I'm sure those inserts are for mini as Spice also do a new series of rims for the mini as well, I found some photos:
Might have to buy a set of the black ABC rims, my white ones shattered on the first run, I couldn't believe it!
Attached Thumbnails Tamiya mini cooper-spice1.jpg   Tamiya mini cooper-spice2.jpg   Tamiya mini cooper-spice3.jpg   Tamiya mini cooper-spice4.jpg
Tim K is offline
Old 01-22-2007, 11:29 AM
  #3086
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
Originally Posted by CCristo
Does anyone know the part # for the long TG10 aluminum servo post/stays? I
This question got lost in all the tire talk. Does anyone know?
CCristo is online now
Old 01-22-2007, 02:02 PM
  #3087
Keith Sawyer's Avatar
Has anyone tried the tires from Take Off for the mini? If so how are they. Thanks.
Keith Sawyer is offline
Old 01-22-2007, 02:57 PM
  #3088
Ok, understood, a bit more questions befoer I get my tires. What is stickier, M or S? and do you think S with hard 60D insert AND hard touring car insert would be too hard overall for carpet? too hard for outdoors?
Carthik
Different tracks will require different combinations, it's better to try a bit of everything and pick out which one runs the best at your track.
trf_racer is offline
Old 01-22-2007, 03:12 PM
  #3089
Tim K's Avatar
TG10 servo posts are #53308
Keith - I've got the RP30 mini tires. The RP tire numbers run in reverse, ie 24 is a harder compound, 30 is mid range and 36 is soft.
On my M03 the RP30's traction roll on most outdoor tracks, only one of our tracks do they not traction roll. I've managed to get them to work well at an indoor track (non-carpet), it really just depends on the surface.
If you're running a Johnson motor they might not traction roll as much, but in melbourne we're running sport tuned motors so we're carrying a bit more speed - maybe that's why I'm getting traction rolls with the RP's, all the other tires work well here.
Also, on the M04 I'm running RP30's on the rear with Pit Shimizu softs on the front, seems to work well
Tim K is offline
Old 01-22-2007, 03:18 PM
  #3090
Thanks, it was the RP30's that I was looking at.
