Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-14-2008, 10:14 AM
  #6226
teabag's Avatar
Hi, just purchased a M-03r, first mini wanted to do a little parking lot race with this. I made it into a M-03m mid lenght chassis i guess. Looked on mini racer website and got a lot of info. A few questions:
are the kit tires useable to race I think they are 60d treaded?
whats the popular tire choice (doesn't have to be tamiya)
Is there a base line driveable setup anyone has or just build it per instructions.
for fine tuning, does shock oil/spring changes make that big difference, or is a mini just what it is and keep the car low to the ground and adjust your driving to the car? it appears oil and spring changes are the only real major options to tune a mini?
I built the car, but hasn't seen any asphalt yet.
thanks for any info.
teabag is offline
Old 02-14-2008, 11:53 AM
  #6227
The kit tires are not too bad. They just wear out too fast.
Major handling changes are done with tires and insert combinations. Small changes are done with ride ht., shock oil and springs. For most parking lots, don't set the ride ht too low. W/out knowing exactly how much grip you have it's hard to make specific suggestions. This is a combination of tires and inserts that seems to work pretty well out here in our California prking lots:
Ride med or hard tire with Ride inserts in front and Rp or Spice tires with the Spice 5.5mm thick inserts in back. No sway bars. You can change the handling more with tire and inserts than with anything else.
Would suggest the following upgrades:
1. ditch the dog bones and get the #53205 universals
2. TAO3 Ball diff and #53217 hardened out drives
3. #53509 flourine coated pinion. These do not wear out like the stock ones
4. TRF shocks
Sorry, I forgot we run Black cans where I'm racing now. If your running the silver can, try using the 60Ds type a slicks in front. Experiment with one set of double stuffs and one set using just foam.
Granpa is offline
Old 02-14-2008, 03:52 PM
  #6228
teabag's Avatar
4. TRF shocks
thanks, I used my old gold trf shocks off my TA03, I guess I'll pull the ball diff off that too.
where do you get the Ride or Spice tires?
I'm attempting to be race ready for Corona Hobbytown this month if there is a showing of mini's.
teabag is offline
Old 02-14-2008, 05:31 PM
  #6229
Vicko's Avatar
Trader Rating: 14 (100%+)
so now that we cant not get any more RP's mini tires anymore
whats do I use on carpet now?
spice or Ride or jsut plan old tamyia?
anyone have used any of these on carpet?
Vicko is offline
Old 02-14-2008, 06:04 PM
  #6230
rccardr's Avatar
Sure can:
try Tamiya S-Grips up front double stuffed with a shortened and glued Tamiya blue 24mm insert on the outside and a Tamiya Jun insert or hard foam on the inside cut and glued to size.
Out back plain old M Grips with Tamiya foam will do the trick. Blue front springs with 80 weight and rear reds with 35 weight.
rccardr is offline
Old 02-14-2008, 08:33 PM
  #6231
If you're talking about Charlie's race (O.C. Circuiit), chances are I'll be there. Look me up. I had to run with the HPI Spec cars at LaMirada and felt like the ball in a pinball machine. It'll be good if we have enough Minis for a race. Most of the Mini guys have been at Tamiya trying to get ready for Doc.
I got most of my tires from RC Market. Warn you though, it's not like dealing with US suppliers. Once you figure out how their policies work, it's not too bad.
If you don't get yoyr tires in time, I usually have some extras you can borrow.
Granpa is offline
Old 02-14-2008, 09:11 PM
  #6232
dag32's Avatar
Trader Rating: 112 (100%+)
I hope after the Tamiya Race all the Minis will come back to Bending Corners Saturday racing. We had about 7 or 8 Minis racing three weeks in a row now there are none . If they don't come back to Bending Corners after Tamiya I will sell the Mini.
dag32 is offline
Old 02-14-2008, 09:43 PM
  #6233
jheimb4897's Avatar
Trader Rating: 1 (67%+)
Default First Body
How does this look for my first body? Done with masking tape and rattle cans. I've already gotten a few complements, and I was thinking of making this my MO for all of my RC's.
jheimb4897 is offline
Old 02-14-2008, 10:05 PM
  #6234
Originally Posted by dag32
I hope after the Tamiya all the Minis will come back to Bending Corners Saturday racing. We had about 7 or 8 Minis racing three weeks in a row now there are none . If they don't come back to Bending Corners after Tamiya I will sell the Mini.
They should be back. Don't sell the Mini, race the regional at Tamiya. I'm looking forward to racing at BCR later in March.
Granpa is offline
Old 02-15-2008, 07:48 AM
  #6235
TryHard's Avatar
Originally Posted by straightspeed
LED torch. You were had. I've now got four little pull back penny wheelie trucks sent FOC with 4 orders. Awsome fun on my desk at work
I've spent £1000's at RC Mart, and I've never had a delayed delivery, a lost item, customs charge or any other problems.
The volume of business they undertake (take a look at their ebay transactions which is only part of their business) will mean occasional problems.
the little truck does wheelies? way cool... mines still in it's wrapper
TryHard is offline
Old 02-15-2008, 09:41 AM
  #6236
asw7576's Avatar
Originally Posted by Core Creations
I believe a little more than 50% of the A mainers in mini at Trackside this last weekend ran the Lipos inlcuding 2nd place. I personally have run the 3200 Orion Lipo for over a year and love it. Just make sure to add a couple oz. of lead to make the car more settled. Since the Lipo is so light it tends to be a little more tippy without weight. Once I added 2oz to the underside of the battery wings the car runs awesome.
Do you have to discharge / recharge after each heat ? or do you just recharge it again after each heat ?
Tks.
asw7576 is offline
Old 02-15-2008, 09:53 AM
  #6237
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Tks.
You don't discharge a lipo pack. Depending on how long your heats are one charge might last two heats. Different lipo's might go longer than that.
Peace Aaron(W-W)
Wicked-Wayz is offline
Old 02-15-2008, 05:54 PM
  #6238
tony gray's Avatar
Originally Posted by Tim K
The runtime was the same, at the 22 minute mark the mini would start to slow a bit, at the 28 minute mark the novak lipo cutoff would kick in. This was the same for the intellect 4200 & the orion 3200 carbon lipo, same mini running a sport tuned (black) motor.
See above for the answer....
tony gray is offline
Old 02-15-2008, 09:09 PM
  #6239
I got a question for any of you mini guys. I probably know most of the answers now but I am having brain farts. I want to know what hop-ups from the mo3 will work on the mo3m. My mini has alu steering knuckles, sway bars, tao3 ball diff, cva short shocks, carbon shaft set. What out of all of that can I still use, I know the shocks & diff for sure the rest I dunno. Please let me know asap.
Peace Aaron(W-W)
Old 02-15-2008, 09:51 PM
  #6240
tony gray's Avatar
It doesn't make ANY difference whether its an M03 or an M03M Aaron.... They'll fit on either.
The only thing which will be a problem is the steering knuckles as the M03M has a different front end and the old style alloy ones won't fit. But you don't need em anyway on the M.
