Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-26-2008, 04:49 PM
  #6976
Hyde's Avatar
novak gtb is 4-6 cell or 2c lipo.
4 cell is used for 3.5 with 1:12 scale or 5 cell tc.
its no problem.
Hyde is offline
Old 07-26-2008, 05:25 PM
  #6977
MD
MD's Avatar
Trader Rating: 136 (100%+)
Someone has probably mentioned this already, but I'll ask any way. Has anyone run the 3racing tires for the M chassis? If so, what was your experience? What's the best tire for the parking lot?
MD is offline
Old 07-26-2008, 07:32 PM
  #6978
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I thought this thread may be of interest to those who frequent this thread.
http://www.rctech.net/forum/showthre...=1#post4677067
mrrcguy is offline
Old 07-26-2008, 08:46 PM
  #6979
Tabushi's Avatar
Guys, im posting this for a friend in Chile, southamerica, in my country its very hard to find tires for mini cooper class, do you have any information of non tamiya alternative racing tires and rims and where, online, to buy them ?
thanks a lot !!
Tabushi is offline
Old 07-26-2008, 09:42 PM
  #6980
reenmachine's Avatar
Trader Rating: 26 (100%+)
There is no particular best tire -- it all depends on your particular track conditions. Lately I've been running the 3racing tires and like them, mostly because they're super cheap.
Really though, the 3racing tires have been good for me. I race on smooth asphalt treated with grape soda, so it's pretty grippy. Tamiya Type A 60D slicks cause me to traction roll. The 3racing tires are a bit grippier than the kit box treads, which actually work pretty well on our track, and are a heck of a lot cheaper. I definitely think they'd be worth a try on a parking lot track.
reenmachine is offline
Old 07-26-2008, 10:12 PM
  #6981
over gear's Avatar
Trader Rating: 18 (100%+)
Questions??
Do you guys feel a difference in speed with a stuffed D60 type-A tire? i tried today with double inserts and a set with just foam inserts... i don't feel the difference in top speed. too bad i didn't have a timer to count lap time...
the type-A is belted, no matter how much inserts i stuff inside, i don't see a major increase in diameter. what do u guys think?
over gear is offline
Old 07-26-2008, 10:24 PM
  #6982
caltek1's Avatar
Trader Rating: 38 (100%+)
over gear,
When you double stuff the tyre you are actually making the tyre firmer and preventing the tyre from tucking under. With just the single foam the tyre rolls in the corners and then you will see the outer side wall has a round edge on the tyre. The double stuffing makes the side wall of the tyre more rigid and prevents some tyre flexing.
With the double stuffing it makes the tyre firmer and assists with preventing the tyre from distorting.
I know that when I was using 60D Type A's, I always ran them with a touring car insert and a Mini foam insert. The double stuffing was only used on the front tyres. Run your hardest tyre at the front and softest on the rear.
Due to the poor wear characteristics and the marginal performance gains of the Type A's, I no longer use them on asphelt/bitumen or concrete tracks.
My thoughts.
Later
Calvin.
caltek1 is offline
Old 07-27-2008, 12:43 AM
  #6983
R/C Tech Elite Member
monkeyracing's Avatar
its no problem.
Well, the one I've been offered is the one that actually says "4 cell" on it, which is the basis for my concern. I found the instructions for it, and they mention to not use more the 7.2v, rather than the 7.4 I thought it could handle. Considering my stick packs will easily peak into the high 8 low 9 range, it's a bit questionable.
One thing I know for sure is that the XRS can fit inside the chassis, and I do find that appealing.
I'll give it another day, and a little more advice before I make up my mind. I'm going mini racing tonight, so that'll be a good source, too.
Thanks guys!
Jim
monkeyracing is offline
Old 07-27-2008, 06:14 AM
  #6984
MD
MD's Avatar
Tabushi - Ebay would be a source of tires, 3racing's web site, Tower Hpbbies ships all over the world. I am sure there are a lot of Asian based web sites. Find the stock number of the tire you want and Google it.
MD is offline
Old 07-27-2008, 09:27 AM
  #6985
Hyde's Avatar
ohhh my bad. i had no clue novak came out with a new edition. even if that esc isn't new to them i thought there was only one type gtb.
well man its pretty straight up answer now. you can't fit 4cells in the mini only iof you make your own pack.
its a pretty clear choice. novak had proven its self for many years and you wouldn't be going wrong. and its pretty small so it could fit anywhere you want.
but that esc has all the power you need and wayyy more for mini racing
Hyde is offline
Old 07-27-2008, 09:05 PM
  #6986
You may be right. I struggled all day trying to find a good balance and still have some steering. Got fairly good for the main, but the track got a little slick. Race your Mini next time instead of just in practice
Granpa is offline
Old 07-28-2008, 02:15 AM
  #6987
edwintklee's Avatar
Trader Rating: 23 (96%+)
thanks a lot !!
http://www.rcmart.com/catalog/rc-mch...?cPath=35_1086
here try this, but i dunno if there is other cheaper type...
edwintklee is offline
Old 07-28-2008, 05:12 PM
  #6988
Juanchoyo's Avatar
Default ------ SETUP SHEET ----
Hi guys I've designed a setup sheet for minis and I'd like to spread it alla around Laughing Laughing send me a PM with your e mail and it will go straight there...... Or if you know how I can upload it to a server or something so u can dwload it easy, pls tell me...
By Juan Sebastian Oviedo Suarez or Juanchoyo
C'ya
Juanchoyo is offline
Old 07-28-2008, 05:49 PM
  #6989
Juanchoyo's Avatar
NEWS!!!! Now you can dwload it follow the link...........
http://rapidshare.com/files/13371723...do_S..pdf.html
See ya guys...
Hope to get feedback..... IT'S THE LAST VERSION AND IT IS EXCELLENT NOW AS I WANTED, IT DID NOT CHANGE WHEN CONVERTING TO PDF...... ENJOY HEHEHE
Last edited by Juanchoyo; 07-30-2008 at 06:47 PM. Reason: Change in the download link
Old 07-28-2008, 11:20 PM
  #6990
Update on the Novak GTB 4 Cell thing
I talked to a few people today, and also contacted Novak's tech line. In general, the opinion is that it will be fine to run this ESC with 6 cells, as the loads isn't that much. Novak said that officially, the answer is no, but they know racers who have been doing this for some time with no issues. So, that's pretty cool. Just don't expect warranty coverage.
About those Yeah Racing or 3Racing tires... what have they put in them for foams? Something fairly firm? Medium? Soft as marshmallows? I'm looking for a reasonably grippy, firm tire for racing on carpet. Having them pre-mounted is just a huge bonus. Opinions?
Jim
