Tamiya mini cooper
#438
well I tested my Integy m-03 high speed gear set. Yes it does have higher top end speed. it comes with all gears required and both gears for either the geared diff or a ball diff. the ball diff grear is really skinny. cuts down alot of friction. I already took the gears out though due to the fact that my motor realy didn't have enough kick for these gears. It got really hot so hot in fact that it would burn me if I touched it. I think these gears are better suited for a smaller pinion and a hotter motor. Right now I am just running a old trinity stock motor. I still think with the hotter gears the m-03 was still a bit slower than the m-01 but can't confirm for sure until I get my new reciever and have a drag race.
#439
#440
Originally Posted by CSeils
Would anyone know this one? Does it matter which side the gear on the ball diff is positioned in the gear box? I seem to be hooking & roll only when I turn right and I thought maybe this could be a factor. Any suggestions?
Check to make sure that the car turns the same size circle left to right.
#442
Not sure what to tell you.
Are your shocks built exactly the same?
#443
Originally Posted by Difuser
Turbo yes there is an extender not sure I cannot remember the parts tree that it comes on though.
Aries there you could try the Boxster, Mercedes SLK and I think there was 1 other. They should all fit the 04L Originally they were all on the M02. Another option is to get the long arm set for the TB01 and you can run the Porsche GT1 body from a few years back. IT gets to be a handful with higher HP motors.
Also for shocks look for a set of the plastic shocks they are not the ultimate, but built with care they can perform better than a badly built set of aluminium shocks.
As for shocks, I just got a hold of some spare parts for my TC3 and included in the lot were some associated threaded shock bodies that I plan on rebuilding. Will these fit the M04L or will they be too long? What spring/oil combination do you suggest? Will stiffer springs in the front with 40wt oil all around suffice or should I use lighter oil in the front as well? Thanks!!!
#445
On the shocks it depends on the bodies. I ran the regular alum bodies and it did not leave a whole lot of room for travel when at 4-5mm ride height. Alot of people use the Tamiya super-mini plastic shock to give more travel. For spring and oil it depends on your surface I prefer 2 hole and 40wt with the "neon" blue old rate spring depending on grip. Oh and sorry I put the wrong LA kit it is for the TL01 not the TB. I think the 2 are very similar though.
For bodies you will be able to use any of the Short Wheel Base bodies Tamiya produced. Corolla Rally car, Porsche GT1, Renault, VW GTI mk2 (if you can find one). The later body was the long WB. there are 1 or 2 more but I cannot think of them off the top of my head.
#450
Originally Posted by RED-LINE M03
Since the mini use a direct link between the servo and the steering how much torque is required?
Any preferences of steering servo's?
Is a high speed servo a must in a mini for racing or will this make the car even twitchier?
