Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-25-2005, 08:47 AM
  #451
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default gears ???/
Originally Posted by tamiyarcracer
The gears or more designed for silvercan motors.
If gpwpat motor was getting to hot could he have had the wrong size pinion gear on his old trinity motor since the intergy gears are geared for more top-end? Maybe he needs some new brushes and strong springs for some extra torque?
RED-LINE M03 is offline
Old 06-25-2005, 09:53 AM
  #452
For servos depends on the level you are racing at. I always use digital but I swap one from a Sedan usually when I run Mini again. I at least try to stay with a high toque servo because you are doing double duty with the front axle.
Difuser is offline
Old 06-26-2005, 04:19 PM
  #453
Default Universal Shafts
Which Universal shaft is better and why?
#53205 M-Chassis Unerversal Shaft or the # 53597
Thanks for your support...........
Old 06-26-2005, 07:49 PM
  #454
tamiyarcracer's Avatar
Originally Posted by RED-LINE M03
Which Unerversal shaft is better and why?
I'm a fan of the 53597, you can get the cross joint and the wheel axle as a spare. the old uni you can't.
tamiyarcracer is offline
Old 06-26-2005, 08:18 PM
  #455
raffaelli's Avatar
I have a pair of box stock cooper for sale. Some extras including alum front knuckles. Email me. [email protected]
raffaelli is offline
Old 06-26-2005, 08:26 PM
  #456
Slotmachine's Avatar
Exclamation Call out
I`m looking for 2 bodies. First I want another Honda S800, 2nd. I am looking for the Alfa Ro`meo. Anyone have these I am interested
Paul Rush......................
Slotmachine is offline
Old 06-27-2005, 01:05 PM
  #457
nozauta619's Avatar
HPI tires
I was wondering if the new HPI vintage wheels and tires will fit with the tamiya m04m (muscle car dragster look). I believe the front is 26mm and the rear is 31mm. I have the tamiya m04m alfa romeo body and do you think I would need to trim the body? I am curious if anybody else has thought or tried out this? I dont want to purchase these wheels and tires if it will not work. Any advise would be appreciated. Thanks in advance.
Anthony
nozauta619 is offline
Old 06-28-2005, 02:06 PM
  #458
killingtime's Avatar
Default ???????????????
Can anyone tell me which part number I need so that I can shim the wheels on my MO3 mini cooper. I have ALOT of play in there I need to get rid of. Also, I know the old johnson motors are the best, but I need to buy a new one. I want to stay TCS legal, so what is the part number of the best, legal motor I can put back into the cooper. Thanks for the help!
killingtime is offline
Old 06-28-2005, 05:21 PM
  #459
53587 5mm SHIM SET 10PCS
53689 540-J MOTOR
All the motors are pretty much the same. how you break them in and care for them make the difference.
Old 06-28-2005, 06:41 PM
  #460
Thanks for the help! Since I've very recently purchased my Cooper, I've found this thread extremely helpful.
Do you have any tips on breaking in the motors? I know water-dipping is the popular break in, but for how long? Anything else I can do to squeeze more HP out of it?
Oh, and one last thing, what website do you recommend to get Cooper parts from?
Old 06-28-2005, 06:43 PM
  #461
As the brushes get smaller the way the motor is designed it advances the timing Automatically.
so at least water dip it till you have full brush contact. you can go further is you want.
This is all I have done, there are many other rumors out there. but I know this works well.
Old 06-28-2005, 07:03 PM
  #462
What about a recommended website to get parts from?
Also, what are the rules on opening the can? Is it a no-no, or can I treat it like my non-locked endbell stock motors?
Old 06-28-2005, 07:05 PM
  #463
A no no
Not sure online who care many mini parts. Speedtech could get you most anything.
Old 06-28-2005, 07:09 PM
  #464
once again, you are a wealth of good info!
Old 06-28-2005, 07:22 PM
  #465
Talking KILLINGTIME!
Mini`s have been added to the big race in Frederick. The new flyer will be posted soon!
Here is the link for the entry form.
http://10-photo.com/hotlink/entryform.html
