Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-29-2005, 08:54 AM
  #466
killingtime's Avatar
Thanks Slot! I need to get as much track time in under my belt as I can, especially if I'm racing against that Casey character
killingtime is offline
Old 06-29-2005, 08:58 AM
  #467
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
If I get my Mini to work I might have to pull double duty that race weekend. Need a few more things for the Mini and it will be ready. I could have it ready to run this weekend but I need some rims and tire inserts for sure and mini Tamiya prings would also be nice. No hurry as I will get the stuff soon.
wyd is offline
Old 06-29-2005, 09:28 AM
  #468
WYD - I know HTUSA in GB has tires and rims in stock. I might be able to pick them up for you. If you're not in a hurry, you can call and reserve them fo rlater pick-up. LMK.
Old 06-29-2005, 10:52 AM
  #469
if you are looking for Tamiya cooper hop ups and tires. the best prices I have found is RCBOYZ. they have an ebay store and a website. I just wish I had sombody to race with here. I have my car all set up and nobody to play with. Now that I have 2 set up I will get my neighbor to play with me.
gpwpat is offline
Old 06-29-2005, 11:29 AM
  #470
Nova F1 Racer's Avatar
Call hobbyworks in Rockville, MD.... They carry them or one of the other HW will have them. If need be, I can alosi pick them up for yee...
Nova F1 Racer is offline
Old 06-29-2005, 11:31 AM
  #471
wyd
Tech Legend
wyd's Avatar
Thanks Mike appreciate that. If it comes down to that I will let you know. Thanks again for the help.
wyd is offline
Old 06-29-2005, 11:32 AM
  #472
wyd
Tech Legend
wyd's Avatar
Thanks I also appreciate your help to. I think I will give RCO a try one last time and see if she has anything in stock. Might roll down Friday since I'm off work.
wyd is offline
Old 06-30-2005, 05:23 PM
  #473
OK... I'm getting &%%&%)*^$#@#%^
I bought the Tamiya universals ( tamiya 53597 ) for my M03 and I can not get them to fit right.... They bind up in the out drives, even with out the rubber o-ring.....
WTF am I doing wrong here??????
Old 07-01-2005, 05:50 AM
  #474
nm
MartynD is offline
Old 07-01-2005, 07:08 AM
  #475
think the drive cups are a different depth from the gear diff to the ball diff, but I forget which way
I thought so too I've tried it both ways and then using the ball diff and well as the stock bevel set... I spent close to 4 hours trying to figure this out..
I tried the following combos..
Stock steering arms, Tamiya universals, metal bearings, stock and ball diffs
Stock steering arm, Tamiya universals , plastic bushings, stock and ball diffs
metal arms, Tamiya universals, both types of bearing, stock and ball diffs
I broke one of my stock dogbones.....
Old 07-01-2005, 03:16 PM
  #476
Jam-ehz's Avatar
There are different drive cups between the Manta Ray/TA03/Gear Diffs.. I have the TA03 diff, and the drive cups themselves are right up against the plastic of the gear case, give a mm or so... Is there a space in between yours? I remember seeing another ball diff kit with slightly longer drive cup shafts, and my LHS noted the difference in lengths before i bought the wrong one. Mine are shiny metal cups, and some others I've seen are had a kind of dusty-coated cup. Not sure if there was a difference with those or not...
Jam-ehz is offline
Old 07-01-2005, 04:28 PM
  #477
BINGO!!!!!!!!!!!!!!!!!!!!!!!!!!!
The "longer" one with the stud is about 4mm away from the gear box....
I'll have to see if I can find the "shorter" version of the drive cups..
I have the Tamiya ball diff hop-up...
THX
Old 07-01-2005, 08:50 PM
  #478
Have dremel, will modify one of the old drive cups....
AND it worked...... Well, I'll let you know tomorrow after racing....
Old 07-02-2005, 05:40 AM
  #479
wyd
Tech Legend
wyd's Avatar
Glad you got it fixed.
wyd is offline
Old 07-02-2005, 07:16 PM
  #480
If it'd not one thing then it's another.... The "homemade" fixed worked great.. No problems with that..... BUT...
Servo, servo saver, wrong servo adapter.... Did I mention a problem with a servo today....
Loking forward to a testing session next Wednesday.....
