Tamiya mini cooper
#4471
TenzoR - go to jasons store, then look for the "Tamiya M-chassis" category.
If that doesn't work, just do a store search for M03. The parts are still there.
minidriver - have you tried the Novak 13.5 b/l in your mini? the speed is comparable to a sport tuned motor ... but if you run 60D's on the front - whoah!!! lots of speed!!! and lots of tyre shredding
#4473
Heya, Mini gurus..
I've been using a normally-built ball diff on outdoor tracks, and it's been pretty good except when I want to accelerate, sometimes one tire can slip.. It has some tension unlike a gear diff, so it does move forward, but I want it to go no matter what..
I stiffened the diff up with extra cone washers, to the point it won't slip at all but I can still turn it, but the turning radius is totally wider, and it understeers like crazy..
I guess the only way people do it is letting the rear slide to follow the front where it wants to turn, and it snaps back into place when they hit the throttle..
Does anyone have a decent setup that works on asphalt like this, or should I be getting a front one-way for this like some have?
Head over to RC-MINI and steal their setups. They are all based on asphalt outdoor tracks - and most guys run this set up with a variation on the theme if needed
The rear tires they suggest may be a bit tough to source as they are out of production now - but 60D's on the rear will probably be sufficient to give you an idea of how it will go.
#4474
planning to run a stock 27t motor in my m-03.
16T pinion?
Thanks.
Will
16T pinion?
Thanks.
Will
#4475
Go to town and put in a 20 - no point in driving it around in 2nd gear
#4476
Been a recent discovery of gold here in Bendigo - this one is much more interesting that the real gold though
#4477
Only 4 pairs? I mock you openly Mr Tasca...
Although given that I ain't racing much at the moment mine will probably perish of old age before I get to use em!
#4478
Well, thats on top of the 2 new pairs that are already on the cars and the 4 pairs that are already glued to rims and in the tire box.
Yeah - i think i'm set for the next 3-4 years
The set that i've used is 6 months old and not even close to showing wear - and thats 2 - 3 race meetings a month! so i think i'm safe
#4479
The ratio for a 16T pinion in a M-03 is aprox 7.24. Better to run stock.
I think I would rather run a 16T pinion.
#4482
Some of you guys might be interested in this thread on the rc-mini.net forum
here
Let your imagination run wild
here
