Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-04-2007, 09:08 AM
  #4156
Core Creations's Avatar
Trader Rating: 108 (100%+)
I would just replace all of the suspension plastic parts. They are pretty cheap and I'd bet that will fix it. Since it was pre-owned I'd bet those screws were takin in and out a lot and were loose to begin with. Once built you almost never need to take those screws out, so you should be good then.
Core Creations is offline
Old 06-04-2007, 10:09 AM
  #4157
Originally Posted by RandomFellow
I just saw on RC Champ's website some listings for what looks to be a NEW M-03M Suzuki Swift SP1600. See here:
http://sv09.wadax.ne.jp/~rc-champ-jp...f2a5a0a033b0e5
Does anyone know what this is and what changes were made from 58368?
Do you have a part number for this? My browser is not putting up Japanese characters and so I have a jumble of question marks.
tarheelquality is offline
Old 06-04-2007, 10:19 AM
  #4158
Just a lightweight version of the Swift body...everything else is the same as the standard Swift kit.
Old 06-04-2007, 05:12 PM
  #4159
RandomFellow's Avatar
Originally Posted by Sydewynder
Might not be anything special but the translation does mention light chassis. Probably bad translation.
M-03M chassis adoption of wheel base 225mm > The chassis the actual car loading the motor onto the front in the same way, adopted the M-03M chassis which drives the nosewheel. As for the frame which becomes the framework of the chassis being light weight slim, there is a strength, the resin make monocoque type which also assembly cheapness pursues. Approximately it equipped lightweight upright, double wishbone 4 wheel independent suspension and the wheel base which is set to 225mm going hand in hand, sharp cornering high travelling stability is produced. Furthermore, total 8 equipping 1050 ball bearings which are in the bearing of the wheel axle front and back, you held down drive loss. In addition, the 60D radial tire where tread pattern is cut was installed on actual car similar 11 these spoke wheels.
Yeah, I read the same translation from Google. There is that sentence: "As for the frame which becomes the framework of the chassis being light weight slim, there is a strength, the resin make monocoque type which also assembly cheapness pursues." Just wondering if they decided to release a graphite chassis. Of course, with this translation, who the heck knows what "assembly cheapness pursues".
And did anyone else think it was odd that Suzuki translated into "sea bass"?
RandomFellow is offline
Old 06-04-2007, 09:55 PM
  #4160
bulldog2's Avatar
Originally Posted by pole_position
Hi guys,
I keep having this problem of the entire steering & servo section jerk to either direction (like the torque steer effect...) when throttling my M-03R.
I have checked. There are no blinding components in the entire suspension, steering assembly, the suspension joints are moving freely.
Any advice on how I can cure this problem? (Can't have the car jerking to one side everytime u throttle out of a corner... )
Appreciated
If you are using the servo saver that came with the original kit the return sometimes get stuck and that will cause your car to steer right and not return
kindly check that and if it is the problem please put in a shim in between the screw and the plastic (shim)came with kit . Also ensure shim size is smaller than the outer saver.Also you can use tlarge tensioner that comes with Tamiya servo saver and wrap around original plastic servo saver to induce return.(TCS/TAC legal
If not above must be the outdrivers coming loose. check that and use CVD's
bulldog2 is offline
Old 06-05-2007, 07:31 AM
  #4161
H I
H I's Avatar
Trader Rating: 18 (100%+)
There is a fish called SUZUKI in Japan but different spell. Can’t remember which fish but I don’t think it was bass.
I just talked with guy who import pit shimizu tire to Australia and he said they are testing new rubber but not much success yet. They may have something by later this year. Good to know at least they are trying to bring tires back.
H I is offline
Old 06-05-2007, 11:50 AM
  #4162
geeunit1014's Avatar
Trader Rating: 14 (100%+)
what compound tires come with the m03r kit?
geeunit1014 is offline
Old 06-05-2007, 01:17 PM
  #4163
Anybody have a black chassis they would like to sell? Or a local shop that may have one...maybe SIR?
Old 06-05-2007, 01:19 PM
  #4164
rctoyguy's Avatar
Trader Rating: 21 (100%+)
What *is* the black chassis? Is that just a newer model? Anything different besides the color?
rctoyguy is offline
Old 06-05-2007, 01:21 PM
  #4165
The Swift and the newer Cooper come with a black chassis...no different from the silver...just looks better.
Old 06-05-2007, 02:38 PM
  #4166
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
i may have an extra one by this weekend, do you want brand new or somewhat used?
HotrodHopkins is offline
Old 06-05-2007, 02:39 PM
  #4167
I'm looking for a new one.
Old 06-05-2007, 02:43 PM
  #4168
alright. Sry, can't help ya there.
Old 06-05-2007, 03:02 PM
  #4169
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Default Johnson motors
In terms of amp draw, what is legal (TCS).
At what voltage is this checked?
mrrcguy is offline
Old 06-05-2007, 03:27 PM
  #4170
I believe 1.3 amps at 2volts.
