Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-02-2007, 06:07 AM
  #4126
Core Creations's Avatar
Trader Rating: 108 (100%+)
2 hole pistons...70/50wt oil...2-3mm front 4mm rear. It won't drag!
Core Creations is offline
Old 06-02-2007, 03:08 PM
  #4127
We know it won't drag but that what most tracks use as a rule. Following what was set for TC
Sydewynder is offline
Old 06-02-2007, 03:25 PM
  #4128
If they are trying to enforce sedan rules on a mini than that's a mistake. If your run at 5mmon carpet the car will be much more tippy...but if that's your track rules then...
At most tracks they clean your bottom chassis right before the qualifier and then check to see if it was rubbing after the heat...no rubbing, no problem. I've run 2mm all winter season long and my car had zero rub.
Old 06-02-2007, 03:34 PM
  #4129
Granpa said his track wants the racers to run at 5mm.
Old 06-02-2007, 03:38 PM
  #4130
Huh, I never saw that in his posts... My bad
He may want to talk to them about that. 5mm on carpet is a bad idea
Old 06-02-2007, 05:22 PM
  #4131
Scottrik's Avatar
Trader Rating: 261 (100%+)
I'm generally of the opinion that if everybody is running to the same rules then no one is at a disadvantage. If the rule is 5mm, it doesn't hurt anyone.
That said, even IF an M-chassis car were to "touch down" there's nothing sharp to snag carpet. "normal" TC's get screws loosening and THOSE tear carpet.
Scottrik
Scottrik is offline
Old 06-02-2007, 05:25 PM
  #4132
Yeah, if everyone is running 5mm then it's fair for sure...you can call it the turtle class.
The v shape of the bottom of the chassis also helps a lot.
Old 06-02-2007, 06:25 PM
  #4133
I'll talk to them about the 5mm rule. Thanx to all for the advice. If you ain't crashin, you ain't trying hard enough
Granpa is offline
Old 06-03-2007, 07:57 PM
  #4134
RandomFellow's Avatar
I just saw on RC Champ's website some listings for what looks to be a NEW M-03M Suzuki Swift SP1600. See here:
http://sv09.wadax.ne.jp/~rc-champ-jp...f2a5a0a033b0e5
Does anyone know what this is and what changes were made from 58368?
RandomFellow is offline
Old 06-03-2007, 10:26 PM
  #4135
Trader Rating: 28 (100%+)
What is the difference?
madjack is offline
Old 06-03-2007, 11:03 PM
  #4136
alana07's Avatar
Trader Rating: 53 (100%+)
looks like the bodyshell comes pre-painted from the factory...
alana07 is offline
Old 06-03-2007, 11:10 PM
  #4137
It looks like the lightweight version.
Tamiya has/had a lightweight limited edition swift body. The babelfish translation said something about a light chassis.
Old 06-04-2007, 01:15 AM
  #4138
H I
H I's Avatar
Trader Rating: 18 (100%+)
It comes with lightweight, pre painted swift body. Nothing special, just a normal M03M chassis. Doesn't say anything about lightweight chassis.
It says release in mid July.
H I is offline
Old 06-04-2007, 02:21 AM
  #4139
pole_position's Avatar
Hi guys,
I keep having this problem of the entire steering & servo section jerk to either direction (like the torque steer effect...) when throttling my M-03R.
I have checked. There are no blinding components in the entire suspension, steering assembly, the suspension joints are moving freely.
Any advice on how I can cure this problem? (Can't have the car jerking to one side everytime u throttle out of a corner... )
Appreciated
pole_position is offline
Old 06-04-2007, 04:00 AM
  #4140
Might not be anything special but the translation does mention light chassis. Probably bad translation.
M-03M chassis adoption of wheel base 225mm > The chassis the actual car loading the motor onto the front in the same way, adopted the M-03M chassis which drives the nosewheel. As for the frame which becomes the framework of the chassis being light weight slim, there is a strength, the resin make monocoque type which also assembly cheapness pursues. Approximately it equipped lightweight upright, double wishbone 4 wheel independent suspension and the wheel base which is set to 225mm going hand in hand, sharp cornering high travelling stability is produced. Furthermore, total 8 equipping 1050 ball bearings which are in the bearing of the wheel axle front and back, you held down drive loss. In addition, the 60D radial tire where tread pattern is cut was installed on actual car similar 11 these spoke wheels.
