Tamiya mini cooper
Thanks its pritty much done now only weird thing is in order to turn the correct way compared to the direction i steer the controller so i turn the controller wheel right ( when looking face on to the controller) the mini goes right i have to have the steering in reverse on the controller and the same thing happens with the throttle it has to be switched to reversed to work in the right direction how do i fix this
OSherman, -love the new body!
Can you tell me, how does this body compare to the JCW you were running? Has it changed the handling at all? Speaking performance only, what can you tell us??
Antlockyer,
I would recommend getting a bunch of practice laps in w/ your Mini. Take notes, tweak your car make adjustments and keep playing w/ it. What happens when you adjust toe-in, camber, shock springs, tires, etc.... I literally spent 2 full seasons getting my car dialed in. Once you are dialed in, it really isn't about speed so much as driving in my opinion. I raced yesterday, I dialed my timing way down as our track was a shorter tighter track, -so speed really didn't make a difference. I wanted low end punch. Some guys would pull ahead and start to catch me on the straights but the straight accounts for like 20% of our track, ...I spent all the turns pulling back ahead ...not because of speed but because of low end punch/torque and a shorter driving line.
In short, keep tweaking your car and keep practicing.
Mini was our featured event yesterday, had a huge turnout, very competitive. I race w a few guys who compete at the TCS level (B-main guys at TCS ...not like OSherman)!! Anyway, I got 3rd in our A-main. The 1st place guy wasn't even a turn ahead of me. I was in 1st at one point, yet the top 3 of us were pretty neck and neck the entire race. ..anyway, wen't home w/ a really nice trophy, was happy w/ that.
Antlockyer,
If you ever plan on upgrading to brushless motors and also upgrading your ESC and just need a simple stock one, I recommend the Hobbywing JustStock XR10 and the program card. It is extremely easy to use and the one big benefit I like is (this is if you use reverse) I can tap brake several times before it locks into Reverse unlike Tamiya ESC's where you only get one brake before it jams into reverse.
On my private track I use reverse on occasion since it's usually only me and my kid driving at the same time.
Your lucky having your own track i got my mini for building it mostly i have nowhere to run it other than my house i also have 2 kyosho mad force one part truck with a non runing gs-21 engine and one im trying (and failing) to fix with a gx-21 engine then i also have a hpi rush evo that im trying to fix too having issues with the steering servo saver bit unclipping and stopping it steering
Iv just seen the M-05 ver.ll pro chassis kit that i like the llook of
It's a lot of fun driving it and I don't have to worry about others crashing into my car... well, just as long as my kid isn't driving with me.
Seeing how much I've improved in 2 weeks tells me what I need is laps and stick time. I'm already going to the mini clubs as often as I can so I found another place about an hour away that races gt12 and bought myself a car to race there. Purely to get good at mini racing of course
Makes it A LOT more fun to drive vs just going back and forth down the street.Seeing how much I've improved in 2 weeks tells me what I need is laps and stick time. I'm already going to the mini clubs as often as I can so I found another place about an hour away that races gt12 and bought myself a car to race there. Purely to get good at mini racing of course
You should try and find one of them on one of the lists here on RCTech and find out where they race.
You can learn a lot more and have a lot more fun racing with someone instead of just by yourself!
No but I'm probably the only over 40 guy in the UK that doesn't. I'm currently using my KO ex10 from 1996. New car means a new receiver and those 40mhz ones are hard to find here now, plus I'm getting a bit fed up with the giant aerial. "Ant look out you'll have someone's eye out with that".
I'm just trying to decide how much to spend. The DX4C from Spektrum does all I need and I'm sure it's am upgrade to the KO.
295Likes
