Tamiya mini cooper
If you race TCS you might be outside the guidelines so best to check your options. I'm open to any mod since I don't race these days.
I had a few weekends to stop by the local parking lot track to watch or even participate if I had urge, but ended up doing other things. Racing is not a big factor in my RC right now, I just enjoy putting them together, fiddling around with it, and just driving them around for personal enjoyment.
I'm not sure if most people are even aware of the monkeyracing gear diff approach. I've thought about something like that while back, but hadn't tried it until recently. It works, and it works quite well. If you are referring to the oil gear diff, if the diff doesn't leak, I much prefer the oil diffs vs ball diffs for its consistency and very low maintenance.
I'm going to make the shims out of transparency film and stack them up until I get the resistance I want.
http://www.rctech.net/forum/members/...2097-shims.jpg
You just add more of these shims highlighted yellow. I used 2 per side for a nice weighted feel on my near stock M05, you can do 3 per side and work the small screws to get your range of adjustment.
R/C Tech Elite Member
A few extra shims per side, with a tiny smear of anti wear grease. Make sure the screws are tightened very evenly. I wouldn't go so far as to call this the Monkeyracing diff. I learned about it on the forum and just advocate it where there might be a conflict with chassis, budget or rules.
A few extra shims per side, wi h a tiny smear of anti wear grease. Make sure the screws are tightened very evenly. I wouldn't go so far as to call this the Monkeyracing diff. I learned about it on the forum and just advocate it where there might be a conflict with chassis, budget or rules.
How's that offroad track coming along?
Not modest. Honest. I saw mention of shimming the diff on the thread when I first joined in 2008, but no one was terribly clear on the subject. For a bunch of guys who are willing to share, there are still a few spots where they got stingy.
Bob (Granpa) filled me in on the trick about three years ago. My only contribution was drilling an access hole for adjustments, which would probably be illegal under TCS rules, so if you do it and get caught, I don't know you.
You taking the ideas and putting it together into tangible form with a twist deserves applause too. so thanks.
Does anyone know what sponge inserts are used on the tamiya premounted (1016) tires? Soft, medium, hard, super hard?
Hard inserts.
Im excited that there is a new miata body for the M chassis cars, but what I don't understand is why Tamiya has chosen to use the M05 chassis underneath it. I wonder if the motor hangs out too far in the rear on the M06 chassis and thats why they went this route. I hope it fits the rwd chassis.
Looks nice.. I'd run it on my 4WD m-chassis.
Do you know the Tamiya Part number for the body only???
Couldnt find info on the body set only, but I believe the part number for the whole car kit is 58624.
