Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 07-31-2015, 08:59 PM
  #25006
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by M05 newbie
What's the difference between the splines on the servo other than accuracy of center point at install...I. E not using much trim to center after installing. Is there a difference between the splines or is it just a different number?
Just a manufacturer preference. Nothing more.
monkeyracing is offline
Old 08-01-2015, 10:16 AM
  #25007
sakadachi's Avatar
Originally Posted by monkeyracing
Had the same issue using a Kimbrough. Removed the decal from the servo! Added a washer to space it out.
Thanks for letting me know.
I think I'm going to file down the aluminum post on the servo wire side to push the servo forward another 1mm for steering rod clearance, and remove that metal decal per your recommendation.
M05newbie- Unless you're getting an aftermarket servo saver, stay away from Hitec because they are a spline 24 size Tamiya does not offer on their servo saver.
sakadachi is offline
Old 08-01-2015, 10:40 AM
  #25008
The servo saver removed the decal, after which I spaced it so it wouldn't happen again.
Old 08-01-2015, 02:47 PM
  #25009
Here are some pictures of my build of the MF01X (the Suzuki Jimny 4WD M-Chassis) of last Friday.
(you can see the options for high & low setup here)
(the driveshaft is VERY heavy, a lot of weight can be removed if an aluminium version would come available)
(the body in Marlboro colours)
Sorry for the long post.
The dampers are the only thing that we've changed, together with a smaller pinion since the default speed is way too much for this body (even when setup extremely low) and we're organising a race on the indoor track of The-Border.com with the M05 2WD & a separate heat for the MF01X 4WD cars.
All MF01X's have to use the Jimny body because the high body makes it a very fun handicap to drive with & makes for a great race.
Thaan is offline
Old 08-01-2015, 03:48 PM
  #25010
Cool. It's so I I,but not at the same time!
I'm curious: Does anyone else use these holes in the rear uprights to pin in the stainless suspension shafts? I use them, as it eliminates the need for E clips. Grub screw or short m3 screw and you're done.
Old 08-01-2015, 09:12 PM
  #25011
You can always send the driveshaft to ewippler so he can make a carbon fiber version that will be lighter than any aluminum ones....
bertrandsv87 is offline
Old 08-02-2015, 01:06 AM
  #25012
hi everyone
just want to confirm 1 issue.
the ball thrust bearing that came with the 53267 ta03 ball diffs is the same bearing as the 53136 one-piece thrust bearing?
novaris is offline
Old 08-02-2015, 11:17 AM
  #25013
32819toon's Avatar
[QUOTE=Thaan;14120820]Here are some pictures of my build of the MF01X (the Suzuki Jimny 4WD M-Chassis) of last Friday.
Nice colour scheme !
I raced my new v2 chassis today and it was really different. It understeered really badly so I put soft springs on the back which made no difference. Rally blocks on the back worked much better, but the car still has a bit of snap oversteer.
32819toon is offline
Old 08-02-2015, 01:33 PM
  #25014
Originally Posted by novaris
hi everyone
Yes. It's the same.
Just found the Tamiya Parts database. Very interesting.
Old 08-02-2015, 03:25 PM
  #25015
Yes. It's the same.
thanks
I ended up buying the extra bearing because the other site recommended getting a replacement bearing
novaris is offline
Old 08-02-2015, 07:40 PM
  #25016
sakadachi's Avatar
I fixed mine too, thanks for your servo's suggestion.
http://www.rctech.net/forum/members/...-after-top.jpg
Also ground the servo mount post to push the servo forward.
http://www.rctech.net/forum/members/...avox-after.jpg
Car runs great!!
Old 08-02-2015, 07:48 PM
  #25017
sakadachi's Avatar
Thumbs up
Thaan- Great job on the write up and your new truck.
If you have access to an Extra Fine Point Sharpie marker, I draw door lines and other parting lines on my bodies to make it a notch more realistic.
http://www.rctech.net/forum/members/...abre-final.jpg
Here's the pen I use. It's a water based permanent marker. You can use motor spray as eraser if you screw up. Will not wash off or smear.
http://www.sharpie.com/en-US/extra-f...er-sp-00008--1
Old 08-03-2015, 02:51 AM
  #25018
nvm. got it sorted out
novaris is offline
Old 08-03-2015, 08:23 AM
  #25019
hprt's Avatar
Default mf-01x
can someone tell me what the intended purpose of this chassis is? Is it a M chassis specific rally car? It can't be intended to compete against the rest of the M platforms - the final drive alone will see to that.
At least it looks like you can use the 3Racing gear diff in the front.
hprt is offline
Old 08-03-2015, 08:38 AM
  #25020
sakadachi's Avatar
From the Youtube video's I saw where the Tamiya crew was demo'ing this chassis, it is supposedly a convenient all terrain car where anyone can drive basically anywhere, even in small space (like inside apartments in Japan?).
Now if you've seen some of the small apartments in Japan, I would probably do a 1:12 crawler instead. At least then you can have some fun in like a one tatami space area.
For me, I supposed if I do get one, it will be like a rally car? Use maybe a Subaru STI body or something if they release them down the road..? When I first saw this chassis, it reminded me of my CC01, but just smaller.
