Tamiya mini cooper
#2105
Just remember the more you practice with Tamiya products, the better you can do at a TCS race.
#2107
Trader Rating: 31 (100%+)
i used my cooper tires all season long.
#2109
Wow, we really go through a new set of typeA's in two days. One of the tracks we run on is smooth and the other is a little rough. We have a pretty good mini turnout every week, check it out on the Georgia racing forum. I think there are about 22 running on a regular basis. Thanks for the info on the wheels. Keith
#2110
i just got these new tires. they're tamiya ones, 60D. it's labeled M-Chasis Slicks. part number: 53215. they are packaged in plastic (unlike the Type A's that are in a box). all i can say is that they're super hard! will test them out, hopefully they run well. maybe these are good practice tires as Type A's are really soft compound and wear very quick.
badboy, has anyone used these tires here in our area?
#2111
Originally Posted by bizkit1
Hey Tony, it's on its way Also have you or anybody else ever seen a Tech Racing M01-M02 4wd conversion? I need some instructions or something
Hope this helps you out, the instructions are on 1 large sheet. The first file (A) is the left hand side and the second file (B) is the right hand side!
Thanks again,
Keith.
#2112
screw schedule
Hey! Does anyone know what the screw schedule is for a stock M03 Cooper? or better yet: have a pdf of the instruction manual.....hit me up at [email protected]
#2113
Originally Posted by tony gray
K-Models/Kai used to, but that was about 2 years ago. Don't think they do now, and their website appears to be dead.
#2114
Shock problem
Im currently doing up a mini and hit a problem. I have the tamiya purple shocks and the tuned springs. I have tried all 3 different piston rings with 1 2 and 3 holes, ive tried 30 40 50 and 70 weight and still the shocks are too long for the springs. they are always solid and the springs rattle around as the shocks are too long. I have seen people use the yellow front blue rear combo but cant understand how they get the shocks to be shorter so i dont have to add like 4 spacers just to get the springs to meet. (Tried without the spacer and the spring bounced and the lower spring holder fell off..
Someone told me to cut the piston rod.... But ive not seen you guys say that at all....
Please help me get my mini M3L lower. (I put reg springs on, yes they fit alot better but i can limbo under my car.. CG toooo high!!!
Thanks for help
Steve
Thanks for help
Steve
#2115
put o-rings in yr shock body mate. 3 behind and 2 infront if i dun remember wrongly. below the piston rings.
