Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-09-2011, 11:23 AM
  #16111
kaiser's Avatar
thanks for the tip, got a set of s-grips coming for the rear now.
kaiser is offline
Old 11-10-2011, 02:11 AM
  #16112
Default M05 Ballrace Steering
I have an M05 fitted with Tamiya 54191 ballraced steering does anyone know what size the ball races for the steering pivots are its not listed on the manual.
Bosscat is offline
Old 11-10-2011, 09:37 AM
  #16113
durtbag's Avatar
Default 1200g mini?
Since min. weight has been reduced to 1200g, has anybody tried to run that light? I know that the common thought is that minis need weight to work, the whole NiMH to Lipo weight difference thing etc. But can a mini this light be tuned to work? This would be for carpet.
durtbag is offline
Old 11-10-2011, 10:09 AM
  #16114
R/C Tech Elite Member
monkeyracing's Avatar
Most guys are running weight in their car. The advantage is that you can place the weight where it's needed, rather than where it might have otherwise been molded in. A lot of people running M-05s (for example) are stuffing the front bumper with lead weights or gluing them to the outside o the bumper.
It helps get the power down and assists the car in rotating through the turns.
Jim
monkeyracing is offline
Old 11-11-2011, 12:00 PM
  #16115
academygaz's Avatar
Sorry if its already been posted, but Xevo back via Spice?
http://www.area52.cc/news/1511-desir...rsion-kit.html
academygaz is offline
Old 11-11-2011, 01:22 PM
  #16116
joe c's Avatar
ive read through most of this thread and cant find what i want...
anyone running brushless in their mini?
ive got an m03-m and was thinking maybe a 2200-2700kv?
somethimg similar to a 27t stocker; any recommendations?
joe c is offline
Old 11-11-2011, 01:42 PM
  #16117
tony gray's Avatar
Good find Gaz, thats definitely an Xevo Triumph.
tony gray is offline
Old 11-11-2011, 05:20 PM
  #16118
WildManDriving's Avatar
Trader Rating: 30 (100%+)
We use the Hobbywing ezrun 35a/13t combo as a control class over here in Australia.
WildManDriving is offline
Old 11-11-2011, 05:42 PM
  #16119
joe c's Avatar
13t huh?
is it a lot faster than stock?
do you burn through tires and gears?
joe c is offline
Old 11-11-2011, 08:04 PM
  #16120
barts71m's Avatar
Trader Rating: 34 (100%+)
13t huh?
No not faster than stock down here, bout 3 secs off the pace at our local track,
No burnt gears had the same set in for nearly 18 months. Tires are no different than anything else, did a whole year on a set of fronts racing 2 - 3 times a month.
barts71m is offline
Old 11-11-2011, 08:06 PM
  #16121
Hi Joe, we recently started running an Orca Q Spark 2200kv combo in our race series in western Canada. I asked that the motors be built to spec at around 2200kv and they're very close to a (real) silver can, but with more torque. They're built the same as a Hobbywing 13T in that they are a 380 sized rotor in a 540 size can. Very efficient and reliable design. The 13t motors the guys run in Australia are fantastic and reliable, too, but they are closer to a 20t-23t in terms of speed.
Think of it this way: If you're running mostly indoors on carpet on a track where the straight is under 100ft, then 2200kv is about right. If you're running outdoors or on a longer track, 3300kv might be the way to go.
I believe the Orca systems are becoming available to the wider public market towards the end of November and a few shops have them in stock already. The Hobbywings are available everywhere. They're both great systems.
For the Orca, contact Hans or Ryan at Team Orca USA for more info.
Jim
Old 11-11-2011, 11:18 PM
  #16122
I)arkness's Avatar
it also depends on the track surface and compound of tyre, as ive burnt through a set in one race meeting, and so have many others i know.
I)arkness is offline
Old 11-11-2011, 11:29 PM
  #16123
I wonder if they'll be selling the IFS conversion bits for the Chariot. I'm very happy my little beast is no longer a true orphan.
Old 11-12-2011, 02:51 AM
  #16124
k_bojar's Avatar
if notone answered you yet...
you want 850 bearings, if looking for tamiya sized/named bearings
basically, you want a 5x8mm non-flanged bearing
k_bojar is offline
Old 11-12-2011, 04:21 AM
  #16125
joe c's Avatar
No not faster than stock down here...
Originally Posted by monkeyracing
Hi Joe, we recently started running an Orca Q Spark 2200kv combo in our race series...
They're built the same as a Hobbywing 13T in that they are a 380 sized rotor in a 540 size can. Very efficient and reliable design. The 13t motors the guys run in Australia are fantastic and reliable, too, but they are closer to a 20t-23t in terms of speed...
Jim
Thanks for the answers, guys.
Jim, after all that info I hate to admit that I won't be racing;
just bashing around in my basement and a bit outdoors.
(my basement section is about the size of the track at my LHS)
I'm not looking for crazy speed; I'm more concerned with damage to the drivetrain.
joe c is offline
