Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-14-2011, 11:39 AM
  #16141
Default M05 RA????
Hi
Just looking at getting an M05 and have been offered an RA spec chassis,
What is the difference of the RA and if it can what is needed to convert to std M05? Does the RA just have higher ride height?
TEMsport is offline
Old 11-14-2011, 03:44 PM
  #16142
I found an interesting issue with my M 03 that I thought I would ask you wise-old-sages about. I recently disassembled my 03' to get it ready to race a carpet series (TQ Raceway). After I reassembled the car, I found that the rear camber seemed to be zero on the right, but was positive 1 degree on the left (Top of tire leaning out) using 2 degree Tamiya plastic
hubs. I replaced the "A" arms, upper fixed links, both hubs, hinge pins, pivot screws, ball studs and made sure the shocks were equal length with a digital caliper. At arms level the left side has 1 degree positive camber and zero degree on the right.
I have never noticed this before and nothing I do seems to correct it. I know a set of adjustable camber links will allow me to adjust it, but has anyone else noticed a difference from side to side? Are the parts molded slightly off?
Graphitedust is offline
Old 11-14-2011, 04:23 PM
  #16143
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by TEMsport
Hi
It's pretty much a few suspension pieces that make it what it is. I think it's the front and rear hub carriers.
monkeyracing is offline
Old 11-14-2011, 09:31 PM
  #16144
something i am working on
utotd2 is offline
Old 11-14-2011, 10:01 PM
  #16145
mailboxck's Avatar
Are those F1 wheels??? (I'm more interested on the chassis than the body )
mailboxck is offline
Old 11-15-2011, 03:30 AM
  #16146
Sith Lord's Avatar
Trader Rating: 21 (100%+)
I think you may struggle for traction....... Body looks good though
Sith Lord is offline
Old 11-15-2011, 11:28 PM
  #16147
akura2's Avatar
THat looks sweet... if those are F1 wheels.. I wanna see what tires you plan using to get them to fit
akura2 is offline
Old 11-16-2011, 02:58 AM
  #16148
Just curious if anyone found using the lower hole of the rear aluminium upright useful? U know it reduces camber gain, but is the effect significant?
stocker is offline
Old 11-16-2011, 06:22 AM
  #16149
Scottrik's Avatar
Trader Rating: 261 (100%+)
What does the hot ticket seem to be at present for LiPo packs in the Minis seem to be? Need the round-sided packs (not sure what the new M05/M06 take).
Thanks.
Scottrik is offline
Old 11-16-2011, 07:30 AM
  #16150
jsinclair's Avatar
Thanks.
I have these http://www.hobbypartz.com/98p-25c-2400-2s1p.html I would have got the 3000 mah if they were in stock when I ordered them.
jsinclair is offline
Old 11-16-2011, 07:48 AM
  #16151
kaiser's Avatar
i've got a couple of thin 3000mah softcase turnigy(practice packs) that i run a peice of foam under as well as a 3500mah hardcase orion that i use for racing.
kaiser is offline
Old 11-16-2011, 11:16 AM
  #16152
tony gray's Avatar
Pretty much all the rc-mini team run THESE.
They have the rounded edges, hard case, and they also use the Corally style connectors so you dont have wires poking out the end and making the car body bulge out.
tony gray is offline
Old 11-16-2011, 11:37 AM
  #16153
I use the Reedy Wolf Pack lipos
ruknd is offline
Old 11-16-2011, 01:37 PM
  #16154
im with TG on this one.
the intelect 3800 50c
got them for the mini.... now using them for short course(10.5T) as well.
and a mate borrowed them and placed 2nd in mod TC last night.
very impressed with these for the price.
cheers
a
ado1974 is offline
Old 11-17-2011, 07:29 AM
  #16155
joe c's Avatar
looks great so far...
lets see some more!
joe c is offline
