Like Tree6Likes
Tamiya Ta06
Old 03-16-2016, 08:09 AM
  #2581
katana's Avatar
Trader Rating: 18 (100%+)
This will be my first TCS, well racing in general in many many years! Typically I'm just the mechanic for all my son's cars including this one. This chassis is just fun to wrench not because it is simple, it is challenging.
katana is offline
Old 03-16-2016, 03:37 PM
  #2582
F1Jet's Avatar
Originally Posted by kwkride
Very true! I ran my TA06 in GT3 again this year. I've never been competitive with it (4th in the "B"), but it was still fun.
Good luck with yours!
The TA06 won the Tamiya Worlds in 2015
youtube has it in action:
2015 Tamiya Worlds GT heat 2 https://youtu.be/coafm2DBaKU
Also
Rod Canare's Tamiya Worlds GT heat 2
2015 Tamiya Worlds GT heat 1
F1Jet is offline
Old 04-10-2016, 07:26 PM
  #2583
fyrstormer's Avatar
Originally Posted by atomic garden
The body looks great, but damn, the wiring arrangement looks terrible. (not your fault.) I think I'd put the ESC on the same side as the servo, so the thick motor and battery wires don't have to pass through the belt, and the thin 3-wire harnesses for the ESC and servo could snake down the side of the battery box to get to the receiver underneath the belt. But the fact that the belt is completely exposed, combined with having a bottom-load battery tray that doesn't actually do anything to manage the battery wires, is a big problem. How are you supposed to keep the battery plug from flopping around and banging into the belt while the car is moving? You'd have to take the body shell off to properly secure the battery plug to keep it from flopping around, which ruins any convenience you might get from the bottom-load battery tray. At least my XV-01s have the electronics stuffed into a little covered box next to the battery tray, so the battery plug is automatically contained.
*sigh* So close, Tamiya, so close.
fyrstormer is offline
Old 04-11-2016, 01:10 PM
  #2584
speedy_w_beans's Avatar
If you can still find the R-Sector RS6 conversion chassis it swaps the servo and ESC mounting locations, which makes the wiring much more manageable. The battery box also loads from the top. Tamiya released a TA06MS kit a year or two ago that also has the servo and ESC positions swapped. If you can't find either of those, then Tamiya did eventually release the TA06MS steering bellcrank so you can use it with a standard TA06. This is the critical part needed to make the ESC/servo position swap possible. With the servo and ESC swapped it's just a small servo lead that needs to pass between the belts (or between the motor and battery box if you plan ahead).
speedy_w_beans is offline
Old 04-15-2016, 10:52 AM
  #2585
Fran's Avatar
Trader Rating: 213 (100%+)
When using the R-Sector RS6 conversion, do the body post retain their origonal position? I'm going to be building a TA06 w/ this conversion and want to use a Tamiya 50769*3200 Nissan R390 GT1 body.
Fran is offline
Old 04-15-2016, 02:50 PM
  #2586
tobyzhang's Avatar
Trader Rating: 15 (100%+)
yes it will
tobyzhang is offline
Old 04-15-2016, 07:28 PM
  #2587
Fran's Avatar
Originally Posted by tobyzhang
yes it will
Thank you, I'm looking forward to the build!
Fran is offline
Old 04-16-2016, 06:35 AM
  #2588
fyrstormer's Avatar
I saw that conversion kit. It looks great. I'm not in the market for carbon-fiber chassis, though. I don't have pavement clean enough to drive on. CF would get torn up really fast. Carbon-reinforced nylon holds up a lot better when there's grit and gravel on the road surface.
Old 04-16-2016, 07:09 PM
  #2589
Try to order the ta06ms RHS steering arm and the carbon side brace then you can mount the servo on RHS
tommy1030 is offline
Old 04-17-2016, 07:25 PM
  #2590
fyrstormer's Avatar
Noted. Thanks for the tip.
Old 05-02-2016, 05:43 PM
  #2591
fat500's Avatar
Trader Rating: 51 (100%+)
06 pro...the r sector conversion is on ebay for 40 shipped. I gat this one 2 weeks ago
fat500 is offline
Old 05-03-2016, 12:15 PM
  #2592
fat500's Avatar
252369489802 ebay #
Rsector carbon fiber chassis set same one I bought seller has 5 left for 40.00 with free shipping. I got mine in 12 days from asia
A steal
fat500 is offline
Old 05-03-2016, 12:50 PM
  #2593
Fran's Avatar
Originally Posted by fat500
252369489802 ebay #
A steal
I got one of those also, exceptional value! I'm not going to start the build on the new kit with this conversion until I have everything I need. Are there any other reccomended must do's I need to order before I proceed with the build?
Fran is offline
Old 05-03-2016, 05:30 PM
  #2594
fat500's Avatar
YEAH RACING TITANIUM SCREWSET...EBAY
youwill have to fiddle with the servo mt to get it right.
pretty straight forward but no manual comes with it. i just looked at the pics from google
fat500 is offline
Old 06-06-2016, 12:17 AM
  #2595
Set
do you guys have any idea where to get replacement for the aluminum ball diff joint (#54305)?
I broke mine and I would really like to replace the cup instead of buying the whole diff
Set is offline
