U.S. Vintage Trans-Am Racing
#8433
THUNDER TRANS-AM SERIES
2010 On-road Finale
I would like to thank all the racers that came out this Sunday to some really fun and competive racing. Im glad you guys came out to support the on-road program and Thunder RC Raceway.
Thanks to the ATL,Memphis, and Alabama guys that made the trip to race with us locals. I hope all of you had a good time and hope to cya all soon.
special thanks to Eddie and Kody Fry for coming out after a long Saturday to support the Jr TA race and the indoor racing as well...and another thanks to the ramp, again...so much easier in the rain getting up and down...
We had over 50 VTA/Jr TA racers over the last 6 months of racing at the Thunder Trans-am Series. Glad you all made apperance this winter. But after 6 months and 6 MSR's and 50+ racers our point champions are crowned....
2010 THUNDER TRANS-AM SERIES CHAMPION....TIM MOORE
2nd Raheen
3rd Haydeen
4th Bubba
5th Mack
great run from all of you and I hope you enjoy the trophies,prizes,cash and everything else that was given away.
I would like to thank Robert Dirla for taking the reigns of Thunder RC and providing a place to race for years to come....THANK YOU
CYA GUYS SOON AT A RACE NEAR YOU
ps..yep I keep my shirt till next time....and also thanks to Nexus Racing, Eddie, Kody, Bubba, and Hayden for the donations to the St Jude Race in Memphis April 24th
2nd Raheen
3rd Haydeen
4th Bubba
5th Mack
#8434
Hey All, got a question and just looking for your opinion. Do you think VTA popularity is on the rise ? I'm looking for ammunition. Our club is still doing RCGT only. We're simply not big enough to offer more than 1 class yet and I'm also looking at future growth. Personal opinion...I think RCGT may see some serious changes or go bye-bye. No opinions on that required. I do believe that VTA would be a better choice for us in the long run. Now I just need to sell the idea to the members.
#8435
- VTA without timing provides the closest racing I've ever experienced.
- Since VTA is a touring car class, your racers can still use the same chassis to travel elsewhere for trophy races, as opposed to changing to Mini Coopers which would pigeon hole your track as being just a Mini Cooper track.
- VTA is cheap because tire wear is minimal without timing advances.
- VTA is a good draw for newbie dads because they recognize the bodies, and they would buy their kids a RCGT car because the kids recognize the bodies from Forsa or GT.
- And obviously, chicks dig VTA, but everybody knows that!
- 6
- 7
- 8
- 9
- 10
#8436
Tech Legend
#8437
Chicks dig VTA !!! Now I'm really sold !!!
Cain, you're right about the bodies being the biggest draw for us. As many of you know...VTA in Florida was killed off via the insistence to run more powerful motors and larger batts (13.5 w/6 cell !). At that time we were running both VTA and RCGT. Racing twice per month...1 sunday rcgt,1 sunday VTA ..both using the VTA motor/batt rules. With the demise of VTA many of us, me included, thought we could "market" rcgt better. But, we also didn't see the huge technical advances and issues that were to happen. Now, with Novak stepping up and with VTA's willingness to adhere to the original "intent" of this level of racing...I'm of the belief that VTA has great "market" value while rcgt continues to lean more toward a fine line between it and TC. I founded this club to be more about driving,fun and affordability.
As we grow, I'd like to even expand on the VTA theme by offering extensions of the program IE: Vintage oval and running can motor Cup Racers. Might even let the Cup cars run with the VTA cars like the original series did.
That gives people access to a small variety of body types and makes room for varying budgets. Cup racer being the least expensive, Vintage Oval and VTA would use the same primary rules with the exception of the body and possibly the wheel/tire size.(not sure if the vintage oval bodies from Bolink or McCallister would require 26mm all 4 corners or accept the 31mm out back)
#8438
VT/GT
So maybe the clear line in the sand would be to support tightly spec'd rules for the "realistic" classes like VTA, RCGT and F1, and open the rules for touring car. If newcomers are attracted by the look, let's make it easy for them to take the plunge into racing by keeping the rules simple.
#8439
Top ten reasons to run VTA at your track:
- 6 You can use an older chassis and still be very competitive!
- 7
- 8
- 9
- 10
#8441
Thanks for the input folks. Sunday is club day and I'll make the pitch for a return to VTA. I'm hopeful.
#8442
Re...TC3 Gearing
A couple of Q's for the VTA "GURUS"...
What is the largest pinion that will fit on the TC3 chassis. I have the stock 72tooth spur and to achieve 3.5 to3.75 FDR I would need something like a 50tooth+ pinion!!! With 4cell packs.
To achieve 4.2 to 4.6 FDR for Lipo i would need at least 39 to 43 pinion. Are there smaller spurs that will fit the TC3.
Any help would be appreciated !!!!! I had to run in touring stock as I had the only VTA car. It was fun but I need a lot more gear 17.5 motor came off at 86 degrees and the batteries weren't even warm.
Thanks guys.
Thanks guys.
#8443
I switched my car over to an 88-tooth 64 pitch spur gear.
I also milled some material from the mount and the chassis to allow the motor to roll over. I did it to my car and a buddie's tc4 and it worked flawlessly.
Pics of the mod.
http://www.rctech.net/forum/5357881-post207.html
On my car, however, i didn't do the milling in the first pic. And in the last pic i had to mill some material from the chassis brace to allow for larger pinions. If you take the rear diff assembly out and watch the rotation of the motor in the clamp you'll see exactly where to mill.
Pics of the mod.
#8444
TC3 Gears
If you want to stay with 48 pitch, Robinson makes a 60-tooth spur. Use a 35 pinion and you get 4.29 FDR.You may have to dremel a little of the webbing on the chassis for pinion clearance -- a 2-minute job.
Just FYI, it's best to use a temp sensor to set gearing. Don't go over 160 degrees. And also FYI, FDR rules are going away in VTA when it moves to 25.5 spec.
