U.S. Vintage Trans-Am Racing
#4936
sounds good, but I'd rather see it based on laps instead of time. ...the 'whatever' 200, 300, 500 etc. First team to *00 wins. We let our local discussion die...and need to bring this back to life.
You actually wearing out the tires or just putting in the tire change just to do it/make it more interesting?
#4937
You could always make an endurance race a lap event AND a timed event just in case the event takes longer than expected. Set a layout and determine an average lap time. Lets say the average lap is 15 seconds (on a big track). You should be turning 4 laps per minute or 240 laps an hour. Set the race for 300 laps or 1 1/2 hours or which ever comes first. This will give the drivers some extra time for pit stops and car repair, but will set an expectation for how long the event will be. I think one of the things that kills endurance racing in electric is not knowing how many minutes the race will be.
The more information you can provide your racers about the endurance race, the better the turn-out. Here is some info I would provide if I were organizing this type of event.
- Estimated number of laps or time you could run on a lipo battery.
This helps racers determine if they have to borrow batteries. If you let racers know that they can run 20 minutes on a single charge or xx number of laps, they will see that they really don't need that many extra batteries to compete.
- Estimated time to charge a lipo battery.
This helps the budget racers see that they might be able to get away with running as few as 2 lipo batteries
Since pit stops were mentioned, you might consider tire only or battery only pits stops. Driver changes also make things interesting.
#4938
Have you ever run at Coopers on the Mt Eagle exit?
#4939
Mostly just to add something to the mix. You can use the same tires.... we mark them and if you just swap side to side that's fine. However most don't use their best tires because they do get some wear (we use one car). So the old tires usually are a little ballooned so from picking up crap, to glazed over, to overheated it does help some to get fresher rubber on the car. But like I said its mostly to add a little twist to the race.
#4940
Oh yeah! I know that you prefer it clean. Most of us would rather it be that way. My memory isnt all that, but Im reasonably conifdent that we have run together. Even though I have only been to Skeens' ahem Dirlas track the one time.
thanks for the input on the Enduro racing. Our outdoor season is starting this weekend and we expect to pick up alot of new racers..the outdoor track is alot more 'visible' to the public... then I'll get Darkside/Battman on PR/Event duties.
...you guys allowing 'extra' pit crew outside the Driver, pitman, marshal? someone to help the pitman?... like a battery beoch? lol.
#4941
#4944
waaaaaaaaaaaaaa..... more pics more pics more pics lol.... I'll post my car in a few
#4945
here you go...this was made just for bodies...cya and enjoy
http://www.rctech.net/forum/electric...ml#post5745075
#4948
VTA is gona turn into a Open class because Novak,LRP, Ect are gona come out with a even better speedo or a even more powerful motor and since there are no rules saying what kind of speedo you can run and so far the only rules is the SS21.5 Novak so someone is gona find somthing that is just gona dominate the field then there will be racers going out and spending more $$ just to be able to keep up. So change the rules now. its up to the track on what you can run but for the bigger events were inspection is done thats were it needs to be inforced. either way its done someone is not gonna be happy but the changes need to be made.
