Tekin R1 ESC
#16
Look at the second picture, it appears larger than 1.3" x 1.0". Not saying it is, but it looks like it
#17
Tekin R1 size
That digital scale must be small but I can assure you the R1 is TINY. I am a Tekin team driver and have two of them and when I got them, they were actually smaller than I expected. I mounted one in my B44 and there is a ton of bare chassis showing. Gives lots of mounting options. Compared to my Novak GTB it is roughly 1/2 of the footprint!! If I recall the measurements said it was supposed to be 1" tall too, not really. If you include the solder posts, sure. The case thickness is nowhere near an inch.
#18
man this is funny.. a place halfway around the globe has it and tower's reporting 'early jan' for arrival. just blows me away.
#21
The manual folded up is 5 1/2" x 4 1/4" (more than likely). Just visually comparing it to that. It just simply looks larger than 1" x 1.3" that was advertised. No doubt its small compared to a GTB. The old mechanicals were just slightly bigger than the GTB LOL. What motor you running with it in a B44 by the way?
#22
I'm pretty sure I can order it from my LHS before tower reports availability.
#23
have anyone tested it?
#24
I've been lucky enough to run one. I ran a prototype of the R1 w/ a Tekin motor around a year ago--in a 24 hour race.
Zero malfunctions. No accidental reverse. Just lots of clean, consistant SPEED.
It's been a long wait. But the Tekin product IS worth it and will (as always) make believers.
BE HAPPY damn it!
BE HAPPY damn it!
#25
BE HAPPY damn it!
BE HAPPY damn it!
I'm waiting too.
#26
does anybody know if you can get the r1 pro in the uk also can you use non tekin brushless motors for example orion vortex which i think have the sensor connection on them will this work sensorless or not.
#28
Yes the R1 can run sensored motors, you simply do not need the sensor harness.
#29
#30
If you say sensorless itīs just for the ESC. For the motor itīs not important if there are sensorwires or not as a sensorless ESC canīt make use of them.
The Orion motors (as the Speedpassion and GM) could be run sensored or sensorless so I donīt see why a R1 couldnīt run them.
Canīt speak for other ESC like Mamba but GM Racing do proof since a long time you can make a sensorless system what wonīt go backwards if you donīt want to.
