Around The Table With Paul Lemieux(RC-America/Thunderpower)
#616
Steve: Wow, thats awesome. why didnt we think of that.lol
Lazer guy: Without going their and looking at what is happening i cant say what the problem is. We all know that the xray is a great car so maybe you can help them.
Do they have the same front drive as you?spool,diff,oneway. are their bodies low? is the set ups crazy? What tires? sauce? Check their tire glue seems. make sure that the cars have good rear traction. Last resort, get a bottle of glue and glue up the sidewall of the front tires all the way to the contact patch.
The Bear: Hi. I dont run roll atall. its a style thing but for me i dont like it. if the car needs to roll free in a stock class i just wont lift all the way or not as long in the corner. Maybe i would run a little creep if i was on big track running a one way.
Itchy: i think that you might be able to get away with switching the fronts. i know how you feel.
#617
Paul,
I have a 1/12 scale question for you if thats allowed...
I noticed at Cleveland that you were runnng your servo flat instead of in the conventional position on you Gen-x. I assume you have tested both ways. Why do you like it better? Just curious as we are kind of toying around with it as well.
#619
**the important point is that the lower pivots are going to have a much larger effect, which is why that is generally termed as raising or lowering the roll center.**
like paul stated, try it on the track. moving the pins produces very obvious changes in chassis roll. most times, putting in camber gain seems to make the car roll more despite the marginal increase in r/c. so for the links, the change seems more to do with contact patch (maybe?) than roll.
#620
Jeremy otis: Hi, Im sad to say it but I truley dont know why i run the servo flat. i have not tested 12th scale atall lately, and i am pretty clueless. But i will be working on that. Sorry
#621
seaball: everything sounds good to me. Simply put (I THINK) the lower pins are to adjust the roll center it self and the upper link is more to adjust where the roll center goes during travel and camber gain the same time.
#623
Paul you made the show again? (www.rctvlive.com) You looked tired but I think it was after a long week and you just won.
Sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
#628
Hey Paul, have you ever run with a center oneway ? Under what conditions would I run one ?
Rubber,asphalt.
Thanks.
Rubber,asphalt.
Thanks.
#630
Jag88: I always run a center one way when i am already running the independent front one way. but that is the only time that i run the center one way. Thanks
Jay: good pic, I hope you didnt Google Ralph Burch to find that because it would be weird then.lol
