Hpi Pro 4
OK,OK,OK TALKING ABOUT DOGBONE,TIR AND YES WE SHOULD LEARN TO SEARCH THREAD I UNDERSTAND THAT
HERE'S WHAT I WANT TO KNOW EXPERT PEOPLE!IF WE CAN USE THE TC4 AFTER MARKET DRIVE SHAFT AND IF WILL FIT TO PRO4 I'M NOT ASKING THE AXLE OR DOGBONE ,TIR.I'M ASKING THE WHOLE DRIVE SHAFT.
AND PLS. BEFORE YOU REPLY OR POST READ FIRST,THANK YOU...
*cough*...
I was actually asking how much MORE durable they were. Not IF...
Like i said.. TiR ain't exactly cheap.. so whether it's worth the investment or not. You tell me!
Aftermarket alu bones to suit the stock HPi cvd's are cheap and plentiful. Even if they break/bend etc.. is it still worth getting the TiR's?
(incidentally, i have a full set + spares on the way.. but just wanted a heads up.)
Cheers!
Cheers!
Originally Posted by Manny
How durable are the composite ones? I would suspect after a crash they would spring back to their original shape (or just break in a really hard crash).
Anyway, just get TC4 dogbones. they are so durable.
composite cvd bones are the only way to roll in the rear. lightest of all and excellent durability. i've been running them for quite some time back there and they are almost as good as new.
tc4 dobones will work. axles will not as they are different diamater.
tc4 hd dogbones are the best solution, imo, for pro4 front dogbones for normal use. easily sourced, and last VERY well. only prob is they are blue
TiR from what i hear are the most durable. also they have 2 sets of holes in the bell part of the dogbone so you can use them even longer (tc4 have only 1 set of holes). furthermore TiR parts are very light, and you get titanium axles with modified thread to hold your nut on better. performance wise these are the best for the front. in the rear im not sure if composite bones + steel axles are lighter than TiR setup. only problem is that TiR cvd's use their own size joint so you have to use their replacements (rebuild kit and axles and bones).
also an advantage of running tc4 or composite dogbones is that IRS sells them with pincushions.
so its up to you, if you have the extra money to get TiR cvd's (and can deal with ordering TiR replacement parts) then buy them for sure. if money or sourcing is hard for you then go tc4 (front) or composite (rear).
finally running anything other than the bones mentioned above is basically asking for bendage (with the possible exception of square titanium bones, since i havent really heard anything about those). tc3 aluminum, tc3 steel, hpi aluminum, all will bend quickly in the front.
Originally Posted by xxxkat
Went 30 tonight floodo1.. The "force" was strong tonight..
Originally Posted by floodo1
now i have a new goal
Dumb question I am about to put in the delrin pivot balls do I run them dry or do I lube them like the stock steel ones?
yeah no need to lube the delrin pivot balls.
Registered User
Now that I've worn out the CVD pin holes on all of my TiR bones I'm going to replace them with the beefy IRS TC3 ones and just strip the anodizing. They are more standardized for replacement parts.
The local fast guy at my track runs the TC4 composite bones and they have not busted on him.
I have a second car I am getting together for my son. I am ging to use the composite for him.
I think the composite dog bones will be one of my first "upgrades" on my new Hara Pro 4. I am running the spool and I suspect that the composite dog bones have just a bit more flex for twisting and would thus take some of the pressure off the rest of the front drive train. Plus if they are lighter and less likely to break / bend, its all good.
Ira
Ira
the composite dogbones will break if used in the front. even from a light impact or collision. Racers have used them on the rears with no problems.
Registered User
Best thing about composites is they are very cheap.
yeah i think on my 3rd run with composites and oneway i broke one.
i woudlnt advise to run composite in front ever, but maybe they would last for you
