Like Tree86Likes
Hpi Pro 4
Old 03-28-2005, 03:18 AM
  #10621
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Rene Brons
I have a alu servo/transponder holder.
Does anyone know where I can buy the alu "box" that can contain the transponder and can be attached to the transponder holder.
Xenon Racing makes the Alloy trasponder holder... also OVA makes a lighter Durlin version..
Speedtech should be able to get the Xenon version if you hit them up since they are a Xenon Dealer
-Dave
JDM_DOHC_SiR is offline
Old 03-28-2005, 03:38 AM
  #10622
murfy's Avatar
Trader Rating: 9 (92%+)
Originally posted by yellow15
a quick question: how often do you guys rebuild your diff? i know it depends on how you drive your car but can someone give me a rough idea? like every month? every year? I run about 10 packs a week on average and using stock or silver can on a outdoor track.
and do you just replace that metal plate or you have to replace the diff balls as well when rebuild?
i generally clean out the car every week. but thats not a rebuild job.
every one month would be good but if it is not to serious racing every 2 or 3 months. i try to replace the diff balls and diff plates every half year just to keep it fresh and in good working order.
murfy is offline
Old 03-28-2005, 03:06 PM
  #10623
brushless's Avatar
Does anyone know how much weight could be saved by going with the bearing adapters and using the smaller bearings?
brushless is offline
Old 03-28-2005, 03:14 PM
  #10624
rc-zombies's Avatar
zero...
the smaller bearings are fragile...you'll end up replacing them more often than not...
rc-zombies is offline
Old 03-28-2005, 03:22 PM
  #10625
racer's Avatar
has anyone encountered the problem where the steering is bound up by the steering hubs?
the only way i can loosen the movement left/right steering is by unscrewing the top ball stud and bottom screw.
Thanks in advance!
racer is offline
Old 03-28-2005, 03:31 PM
  #10626
mtveten's Avatar
Trader Rating: 29 (100%+)
Thanks in advance!
It sounds like your over tightening the screws. tighten the ballstud screw and bottom screw until they are just snug then back off about 1/4 turn.
mtveten is offline
Old 03-28-2005, 03:34 PM
  #10627
Scho's Avatar
Where do you get you novak speedos turned black?
Scho is offline
Old 03-28-2005, 03:39 PM
  #10628
racer's Avatar
Thanks, i've checked the manual again and that's what it said to do.
Thanks for the quick reply
racer is offline
Old 03-28-2005, 03:42 PM
  #10629
rc-zombies's Avatar
GTX is impossible to dye..
the GT7 is dyeable with Rit fabric dyes.
Old 03-28-2005, 04:40 PM
  #10630
Racer...I hear your problem....I solved it by filing the inside of the C hub until the steering was free.If you do as the book says the steering block still binds in the C hub.
Barger is offline
Old 03-28-2005, 04:49 PM
  #10631
Trader Rating: 42 (100%+)
Thanks in advance!
The problem is the chubs and knuckles do not fit perfectly...they have some binding. Just sand the top of the knuckle a little and it'll free up nicely.
This was noted by HPI and you could probably read about it waaaay back on this forum. At this point the newer parts may have a running change but I'm not sure.
Nexus is offline
Old 03-28-2005, 04:50 PM
  #10632
racer's Avatar
Barger, Nexus...
Thanks for the help!
racer is offline
Old 03-29-2005, 03:27 AM
  #10633
moot's Avatar
what gearing would be recomended for a trinity Monster Horsepower Pro Stock Motor?
its a reasonably tight track....
moot is offline
Old 03-29-2005, 08:17 AM
  #10634
rc-zombies's Avatar
maybe start around 7 - 7.2 final drive...
Old 03-30-2005, 08:04 AM
  #10635
Mach10_shooter's Avatar
Trader Rating: 40 (100%+)
Default Carbon fiber parts
Ok, I have 2 sheets of carbon fiber one 1/16" (1.6mm) and one 1/8" (3.1mm). I am thinking about making some custom parts for my Pro4. Are there any parts that are currently available but need to be updated or changed to perform better. Also is there anything that is not available that someone would like to see made. All the parts I make will be CAD drawn and CNC cut. If anyone has any good Ideas for some parts and I end up using your Idea I will be happy to send you a few free parts.
Please let me know what everyone thinks.
Chris
Mach10_shooter is offline
