Like Tree86Likes
Hpi Pro 4
Old 03-14-2005, 06:10 AM
  #10471
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Totalfixation
any idea when the 2005 version comes out?
April~May Time frame from what I have been told
-Dave
JDM_DOHC_SiR is offline
Old 03-14-2005, 06:26 AM
  #10472
dmatter's Avatar
I have been Running My pro4 for a Couple of weeks Now with good Results. But, My car Really Holds a Tweak I Will not hit anything and When I do a Visual and Tweak station test the Car/Chassis is Tweaked. I Can twist the Car back Straight Again By hand and it is Fine. Please Help I have never had a touring Car hold Tweak Like this Before, and Yes I tried the 4 Hole Top Deck Mod But Car still holds Tweak. I can Twist the Car By hand and it stays Twisted. HEELLLP!
dmatter is offline
Old 03-14-2005, 07:34 AM
  #10473
1fastdude's Avatar
Trader Rating: 16 (100%+)
Try a 3.0 mm chassis from B.M.I. This chassis is awesome. Battery slots are milled and it seems to stay in tweak. Just my .02 cents
1fastdude is offline
Old 03-14-2005, 08:09 AM
  #10474
dmatter's Avatar
Thanks Eli, I will give them a call. Good work at the Warm-Up Race! Kevin E Said, You and Junior were On Rails. Freakin Old Timers!
dmatter is offline
Old 03-14-2005, 12:46 PM
  #10475
Default Hey
Hi guys I just got my Pro 4 do you guys happen to have any pics of yours just wondering.
thanks
Justin
jumbo360 is offline
Old 03-14-2005, 01:46 PM
  #10476
lee
dmatter
Take a look at the Team Prp Chassis. It gives you a longer wheel base option, top plate that acepts larger spur gears, side gaurds and a plate to keep the spur gear from flexing. It is one of if not the stiffest chassis for the pro 4
Here is a link http://www.teamprpracing.com/
lee is offline
Old 03-14-2005, 01:59 PM
  #10477
rc-zombies's Avatar
dmatter:
if you're running indoors on carpet the PRP or BMI chassis is great choice ... very stiff.
for outdoors stay with the 2.5 or 2.mm optional chassis.
you will loose traction with the thicker chassis.
are you screwing the upperdeck in a star / criss-cross pattern?
rc-zombies is offline
  #10478
rod_b's Avatar
Does anyone have a Pro4 mod setup for SoCal (or any other prepped asphalt track)?
rod_b is offline
Old 03-14-2005, 02:44 PM
  #10479
racer's Avatar
Originally posted by rc-zombies
dmatter:
would a stiffer chassis in general be better suited for rubber or foams?
Thanks in advance!
racer is offline
Old 03-14-2005, 03:01 PM
  #10480
rc-zombies's Avatar
Thanks in advance!
Most likely indoor w/foam.
I have a brand new BMI complete chassis set available for sale if you and anyone else is interested.
Old 03-14-2005, 03:06 PM
  #10481
mtveten's Avatar
Trader Rating: 29 (100%+)
Thanks in advance!
Regardless of foam, rubber, asphalt, or carpet a stiffer chassis will always do the same thing.
In general a stiffer chassis will reduce flex giving the car a more sensative consistant feel.
The more flexible chassis can provide extra grip though chassis flex but the added grip is typicaly not consisant and can numb the car's response.
No regarding the HPI I can say that the stock 2.5mm chassis is well designed and much stiffer than those included with other cars.
mtveten is offline
Old 03-14-2005, 06:45 PM
  #10482
Guo Chean's Avatar
Hey Rc-zombies
about the http://shopping.rcmodel.com.hk web site because to day i going to buy some stuff over there. after i choose my items when i check out it do not mention that it have stock and straight away ask me make a payment. so may i know will it inform you after you have make payment or before? thanks
Guo Chean is offline
Old 03-14-2005, 07:43 PM
  #10483
rc-zombies's Avatar
in your shopping cart is will usually say if the item is out of stock.
and yes on check out..it will ask for payment method etc. and shipping info.
If your are hesitant..being your first time order... email them a note to verify items you want are in-stock or not. Terence usually replies within a day. due to time difference. if you're lucky and catch him very early am..like around 7am Pacific time.. he'll reply back within minutes... Tell Terence you were referred by me.. Ramon . so that I can get more free stuff... j/k.
after you have paid your order..
You'll get several emails giving you status of your order and when it ships.
Old 03-14-2005, 07:48 PM
  #10484
ngo8's Avatar
that a good website to get stuff from very trustworthy and they ship out fast and usually when you add an item if its out of stock it has 2 stars besides it when its in the cart .
ngo8 is offline
Old 03-14-2005, 07:51 PM
  #10485
ngo8's Avatar
hey ramon i got the brace today thanks its very nice to bad the season is over
ngo8 is offline
