Hpi Pro 4
#9121
setups
i just built my car to the latest andy moore setup (with a few small changes) and the car is DIALLED
#9122
Re: Re: Set-ups???
Originally posted by AMGRacer
I used the Hara setup from the ROAR 2004 as a baseline since I run asphalt mod.
What surface you running on? And what tires?
Tires... I am in the process of changing from Elligi 40 Front and rear foams to Sorex 36R (might as well start getting ready for the inevitable)....
I am going 36R as the track temp here in Perth can get quite high, and a few people have already tried 32R and reported the tires overheated
#9123
wats the biggest 48pitch spur gear that can be fitted into the pro4. i tried putting a 86 teeth and it is brushing against the chassis
#9124
Re: ??
The chassis is not your concern, you have to check the gear is actually too big or not cause it might go BELOW the lowest point of the chassis....that might be the problem when you run on carpet, it will drag the carpet, strip the gear and such.....if you run outdoor, your spur will be strip very quickly...
#9126
You have to cut and drill the Buds bumper to make it fit. I believe there is a template on the board somewhere though. Maybe a link to it a couple of pages back.
#9127
Rookie, check your PM.
#9128
Just a reminder, the search function here works
Bumper Info 1
Bumper Info 2
Spur Info
When using a MS Internet Exlporer, use ctrl+F and search for the appropriate terms to find the post quickly.
Bumper Info 1
Bumper Info 2
Spur Info
#9129
what is everyones thoughts for diff/one-way/spool on carpet?
i seem to hear lots of conflicting ideas on which one is the ticket, and when to use each one.
the tack im giong to be racing at has a 1-2 high speed corners, and then evenly mixed between sharp and medium bend corners.
this is for 19t / stock btw.
thanks
thanks
#9130
On carpet? A front diff is the ONLY option. Everything else will make you slower. Check out the carpet setups for both the HPI cars and everything else out there (TC3/ Xray / XXX-S / etc). You won't find a one-way or spool anywhere.
#9131
thanks
thanks
Are you talking about foams on carpet or rubber tires?
foams.....always a diff.
rubber tires....diff or oneway depending on the layout.
#9132
Erik Shauver - setup sheet pdf...
Erik Shauver,
If there ever is a running change to the blank setup sheet pdf file....can one of the changes be that under "Track Conditions" there's a checkbox for asphault or carpet.
Also....is there a 'new' blank setup sheet that uses 'checkboxes' available for download?
I noticed that the setup sheets for E. Andreassen and Andy Moore are a bit different then others (using the check boxes).
Thanks.
Thanks.
#9133
Nexus: We'll try to work that into the next setup sheet (the asphalt/ carpet check boxes. The website has the older version of the sheet up at the moment and should be fixed soon back to the "interactive" version we made.
-E
Oh yeah, for foam+ carpet drivers, check out :Andy Moore's Cleveland Setup
-E
#9134
John
#9135
Don't suspose any one can give me a few more pointers on the pistons used on Andy Moore's set-up
like which number they are ? or are they by another manufacture ?? just that i couldn't tell you which to use just by the sizes ;+(
Oh and with the Roll center spacers is that the total between chassis and the purple mounts or is it assumed that'll you'll at least be using the 2mm purple ones supplied as std. ??
I assume it's a total figure but just want to check to be sure ;+)
Also no rear anti roll bar is mentioned ??
