Hpi Pro 4
#3121
R/C Tech Elite Member
Originally posted by Doug Gaut
The car got many looks throughout the day as well since it is the only Pro4 in town. (For now that is) Thanks HPI!!!!!!!!
I'm still the only one who races at my track with a Pro 4. Well, Proteus did race there, but he left for Japan and forgot to ask me what parts I needed....
j/k Proteus....
Buddha
@ Gary: Let me know if you get my PM ok...
#3122
Any quick suggestions for the rear diff nut loosening other than the obvious like a new nut or threadlock? I tightened it down twice and it still will not stay tight. Is there an aluminum nut that will fit in this application like the Losi used or the newer one piece nut that is being used?
#3127
Does anybody know if there are steel outdrives in production? They worked great in the Losi and make strong spools.
#3128
#3129
Doug- I know that Steve at Speedtech is in the final stages of producing a steel spool for the Yokomo SD. He had them designed and is going to produce them. I bet if there were enough interest maybe he could be interested in doing one for the HPI car.
Guys Doug's car was sweet on sunday. If I did not have my CGM I would look at getting one.
Jeff
Jeff
#3130
Setup Question
I am finishing the setup on my Pro4 and I am having a problem getting the ride hight the same on the left and right sides in the front. The rear seems to be OK. I have even disconnected the sway bars and removed the top deck. This helped, but I am still having difficulty getting the ride hight the same.
I have not balanced the car yet. Could this be an issue?
Thanks is advance.
Thanks is advance.
#3131
Well, I have to say that I am pretty impressed with the Pro4. I battle tested it this weekend unintentionally hitting every PVC elbow on the track and suprisingly made it through the whole day racing 19T and Stock classes with only a bent CVD bone to show for it. On top of that, I TQ'd and won the Stock class. The car is very smooth...almost to the point of looking slow. Very happy with the car.
On another note, what is a good starting point for gearing with a Reedy Quad Mag 19T. I think my motor is just a dog because I tried everything from 39-35 and had no speed on the straight.
#3132
Tech Legend
Trader Rating: 51 (100%+)
I know when I run 19T I normally gear up 2 to 3mm more of rollout to get them motors running strong. I would think that is like 2 to 4 teeth higher than you run a stock motor at.
#3134
Originally posted by EAMotorsports
Anyone looking for a brand new never run pro4 let me know...
[email protected]
EA
[email protected]
EA
#3135
Originally posted by Super Steve
I PMEd ya...
I hope GPM starts making pro 4 parts...
Like knuckles and rear hub carrirer so i can get them off ebay cheap...
I PMEd ya...
