Like Tree86Likes
Hpi Pro 4
Old 06-24-2004, 09:12 AM
  #5746
rc-zombies's Avatar
Originally posted by Skill
I've ordered some alloy steering knuckles and C-hubs from AsiaTees purely for durability purposes. They are Jet ones so hopefully they will hold up well as they look much stronger than the Square ones.
I'll let everyone know if I have any problems.
The jet ones should be more durable...has more metal where the screw goes into... I'd order some as well...but I'm broke...
rc-zombies is offline
Old 06-24-2004, 09:48 AM
  #5747
Regional Moderator
Darkseid's Avatar
Originally posted by Pit-racer
Just got my pro4, and what are the must haves?
I've had good luck with the car in stock form. The only thing I've added is the Square transponder mount and the front diff.
Darkseid is offline
Old 06-24-2004, 10:06 AM
  #5748
Super Steve's Avatar
You guys break c hubs?
I even bent out the pivot block but never broken a c-hub on the pro 4!
I have bent front aluminum body posts. They are bad for running outside i think... (I was running my pro 4 with friend's b4 and we collided head on and he bent my body posts. I bent it back a bit but it's useless) lol
PPL with body posts, do you cut them down?
Super Steve is offline
Old 06-24-2004, 10:08 AM
  #5749
rc-zombies's Avatar
the stock plastic body post I trim down to about 2-3 holes higher than the body. the Aluminum ones I leave alone..but they can be cut down with a dremel or hack saw.
Old 06-24-2004, 10:33 AM
  #5750
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Just got my pro4, and what are the must haves? Or do I have it all RCBuddha?
I think you have it all! You may want to get:
1. new 1.1 version gears
2. HPI Backing plate (if your going to use the oneway)
3. extra arms etc....
You should already be pretty well set-up....
RCBuddha is offline
Old 06-24-2004, 10:34 AM
  #5751
rc-zombies's Avatar
for tuning get
new Pro4 springs and swaybars.
Old 06-24-2004, 10:43 AM
  #5752
RCBuddha's Avatar
Originally posted by onnetz
is that still true with progressive springs?
Progressives should be different, They get harder as they compress, so yes, you could use progressives if you can find them....I'm reffering to regular springs....
RCBuddha is offline
Old 06-24-2004, 11:07 AM
  #5753
onnetz's Avatar
I knew you were referring to linear springs, but I was curious about progressive ones.
I found a few from HPI at towerhobbies...
onnetz is offline
Old 06-24-2004, 11:12 AM
  #5754
kewdawg's Avatar
Progressive springs won't work. They're too long (29mm)! Unless you're looking to run Rally.
kewdawg is offline
Old 06-24-2004, 11:30 AM
  #5755
onnetz's Avatar
yeah I found that out the hard way.. Its what I get for not paying attention when I ordered them.
they didnt work at all for my pro 4 but they do work nicely on the front of my tc3..
I think it depends on how you have your shock geometry set up.
onnetz is offline
Old 06-24-2004, 12:36 PM
  #5756
Skill's Avatar
I've broken several, all in the same way. Once the steering knuckle breaks it puts force on the C-hub and just snaps it, not of the bits I've broken have been a knuckle and C-hub together.
So far I've only ever broken one arm.
Skill is offline
Old 06-24-2004, 12:41 PM
  #5757
kewdawg's Avatar
Yeah I've broken them too. I've never broken a c-hub without at least stripping the hole for the kingpin screw in the knuckle.
kewdawg is offline
Old 06-24-2004, 12:48 PM
  #5758
kewdawg's Avatar
yeah, and that little flanged sleeve for the screw gets broken too.
kewdawg is offline
Old 06-24-2004, 12:58 PM
  #5759
popsracer's Avatar
Originally posted by rc_square24
just a question...in situations where i need a stiifer suspension but have no harder springs.....will cranking the preload and leaving everthing else the same give abit of a stiifer sus. feeling? like for emergencies?
The shock pre-load collars are for adjusting ride height. The spring rate remains the same unless you use different springs.
If you use the droop screws to limit ride height, then the Car will end up handling very poorly.
Sway bars control chassis roll and in general cause that end of the car to have less side bite.
Springs are fairly cheap, buy a few sets in different rates.
popsracer is offline
Old 06-24-2004, 01:08 PM
  #5760
tsolokoy
Do share!!
Doug Gaut is offline
