Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 10-04-2010, 01:50 AM
  #9841
Toh WL's Avatar
i also tried usin the 3m tape..it does holds. but it get loosen as time goes by. this is due to dust n dirt.
Toh WL is offline
Old 10-04-2010, 03:16 AM
  #9842
Murdock's Avatar
Sorry if there is a post regarding this topic. Anyone tried any of the clone versions of this chassis?
Murdock is offline
Old 10-04-2010, 06:10 AM
  #9843
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by RCknight View Post
It's small, is it an issue or can you put it closer to the center line and have enough room? Same thing was done on a TC4 was it not? Yeah they used fans and didn't work well. Would be nice to see the holes for lipos on both sides for equal side to side flex instead.
The Tekin RS on the LiPo chassis works fine, even with the vent cut outs.
This car has been used to win the last 2 world championships, the last one with the LiPo chassis. I think it'll be fine for VTA.
syndr0me is offline
Old 10-04-2010, 06:39 AM
  #9844
RCknight's Avatar
Default I asked if I could taped down a Tekin RS not if it...
was ok for VTA.
RCknight is offline
Old 10-04-2010, 09:23 AM
  #9845
syndr0me's Avatar
was ok for VTA.
Okay, sorry, you're not always exactly easy to understand. Yes, there's plenty of room to tape down a Tekin, with either the standard chassis or LiPo. Use good tape. The TOP stuff seems to be a great choice. The grey 3M works well too.
syndr0me is offline
Old 10-04-2010, 02:02 PM
  #9846
CraigM's Avatar
Trader Rating: 34 (100%+)
just get the air duct piece if you're that worried
I ran pulled out my original 416 for a run on carpet this weekend, with the kit chassis and WE top deck man did it rotate better than the X! I hope with the 417 they've moved the diff back to the original position, the car was awesome to drive
CraigM is offline
Old 10-05-2010, 01:03 AM
  #9847
RCknight's Avatar
Default Expirenced 416 owners....question.
hey guys never owned a Tamiya, but considering the 417. I read that the 416 tweaks easy and I wondered if it was prone to it because of the bulkhead design? Seems you have more chassis flex setting with the 416 because of the extra screws and they are spread out further across the bulkhead. If anyone has expirence with T3 and 416 could you expain if one is less prone to tweak than the another? Any advice on pros cons of each?
Also anyone know if the 417 will also have that large cut out on the chassis and if the servo will hang off it? Seems it would defeat having the narrow chassis. The new HPI car, it's servo does not. Just wondered. Thanks
RCknight is offline
Old 10-05-2010, 01:31 AM
  #9848
HI_808's Avatar
With the 416 it's almost easy to forget that you can tweak your chassis when you compare it to older generations of cars.
I am quite sure that the servo will not hang off the side of the 417.
HI_808 is offline
Old 10-05-2010, 02:00 AM
  #9849
CraigM's Avatar
You heard wrong, the Tamiya doesn't tweak any easier than anything else
CraigM is offline
Old 10-05-2010, 02:01 AM
  #9850
veecee's Avatar
There are plenty of pics on the 417 thread that shows that the servo will "hang off" the chassis. It is not an issue as it has won multiple world championships this way... The TCX chassis is wider which is why the servo doesn't hang off.
veecee is offline
Old 10-05-2010, 05:45 AM
  #9851
RCknight's Avatar
Default Got it...
thanks.
RCknight is offline
Old 10-05-2010, 03:44 PM
  #9852
Raman's Avatar
Trader Rating: 85 (100%+)
Originally Posted by Tron
I've searched as best as I possibly can...but I can't find an answer. If I purchase the Tamiya Porsche GT3 body will it fit a TRF416? I'd like to run a realistic Porsche body. Thanks in advance, Brett __________________ Brett H - A Main Wannabe Caster EX-1.5r, Jammin SCRT10, HPI Blitz, Revo Platinum.
Thats the exact body I presently have on my 416WE.
Front bumper mount holes line up. Rear you will have to make new holes
Wheelbase, I moved rear wheels ever so slightly forward to make 210 wheel base.
Rear wheels are the hard part. You need +6 mm offset to make it look scale. Most +6 mm offset rims look ghetto lol. The stock mesh wheels that came with the kit are +2 mm offset and you can add some axle spacers, but then your lock nut won't catch, unless you use the cerated backed lock nuts.
Raman is online now
Old 10-06-2010, 05:32 PM
  #9853
CraigM's Avatar
Can someone help me with the part number for the universal rebuild kit? I can't seem to find it
CraigM is offline
Old 10-06-2010, 05:51 PM
  #9854
veecee's Avatar
Have a pack right in front of me mate - 53500!
veecee is offline
Old 10-06-2010, 06:10 PM
  #9855
kschu's Avatar
Trader Rating: 16 (100%+)
use shoe goo to stick down the servo, wont be a problem anymore....
kschu is offline
