Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 03-03-2010, 06:14 AM
  #8341
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by artwork View Post
When I first posted them I got very little response...glad to see there is some interest even if it is small.
Cool product. If I had any problems with bent blocks I would consider buying some from you. Alas, I haven't bent any. I run the split blocks up front which seems the most common one to bend.
M-Technic is offline
Old 03-03-2010, 10:17 AM
  #8342
dodo's Avatar
been wondering for awhile and maybe was asked before, pardon if someone already asked and answered before.
why do the suspension mounts has the number '1' in front of the letters.... 1A 1B 1C, etc
it's not like tamiya came up with 2A 2B 2C and so on...
not an important question but just need to 'quench' my curiosity
dodo is offline
Old 03-03-2010, 10:55 AM
  #8343
Hebiki's Avatar
Trader Rating: 26 (100%+)
the original blocks just had the letters... then when the 415 (Ed can correct me on this) came out.. they added the "1" since its 1mm lower than the original.
and you'll probably ask.. what about the difference in "font" between 1A and 1A
the newest blocks that have different lettering are redesigned so you can "flip them over" and use them as bridge blocks to clear the belt. (or chassis brace like in the TB-03)
Hebiki is offline
Old 03-03-2010, 10:59 AM
  #8344
Trader Rating: 20 (100%+)
Well Put Chris!
Sean Williams is offline
Old 03-03-2010, 11:01 AM
  #8345
dodo's Avatar
thanks man!
so basically other than the flipping over, the 415 and 416 blocks are of the same dimension.
dodo is offline
Old 03-03-2010, 11:17 AM
  #8346
94eg!'s Avatar
Trader Rating: 17 (100%+)
thanks man!
yup
94eg! is offline
Old 03-03-2010, 11:29 AM
  #8347
Hebiki's Avatar
thanks man!
yes.. BUT when all the font lettering is the same... you go 0.1/sec per lap faster.
Hebiki is offline
Old 03-03-2010, 02:25 PM
  #8348
Trader Rating: 32 (100%+)
Originally Posted by 94eg! View Post
yup
Not true! For some reason Tamiya decided to make the new blocks shorter than the old. An old 1C block is a smidge longer than the new ones. The same holds true for the rest. Very weird...
ittjv is offline
Old 03-03-2010, 02:31 PM
  #8349
veecee's Avatar
Trader Rating: 34 (100%+)
Put them side-by-side and you can definitely see the difference.
veecee is offline
Old 03-03-2010, 07:30 PM
  #8350
94eg!'s Avatar
Tamiya themselves says the setting is the same. The difference is probably in the material thickness...
http://www.tamiyausa.com/articles/fe...article-id=412
94eg! is offline
Old 03-03-2010, 07:44 PM
  #8351
CraigM's Avatar
measure them
CraigM is offline
Old 03-04-2010, 01:10 AM
  #8352
The old suspension blocks (only A-E) for the 415 are slightly wider then newer 416 ones. The 415 blocks were designed for the old suspension (TA04) on the original 415 which uses ~50mm suspension shafts. This was later changed to 46mm shafts with slightly more toe in the rear as result. This was corrected with the new blocks. As comparsion on 46mm shafts: XA-old E = 3.2 degrees, XA-new E = 3 degrees.
Mr_Orange is offline
Old 03-04-2010, 02:40 AM
  #8353
Toh WL's Avatar
the traditional 415 suspension block looks a bit longer.
Toh WL is offline
Old 03-04-2010, 05:18 AM
  #8354
RC MARKET's Avatar
Tamiya New Touring car shock spring !
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-ta-42168.jpg
RC MARKET is offline
Old 03-04-2010, 07:12 AM
  #8355
There is no white in the pack?
I thought it will be the same as the wilky blue set but black.
Anyway it looks great!
Davzone is offline
