Xray T2'008
Old 08-10-2008, 08:47 AM
  #1366
The Evicerator
yokemad,
Most of the time on asphalt having all of the toe in inboard helps generate more traction/steering and stability... I know it sounds kind of backwards having it do those things all at once... but the toe in on the inside acts to sort of "bind up" the rear suspension similarly to how antisquat would... this helps with forward accelleration, weight transfer, and mechanical grip.
Originally Posted by yokemad
Hi Guys
My Car has 1 degree outboard TOE But I've noticed 90% of the setup sheets has no outboard TOE....
Why is that?
Why many drivers prefer 0 Outboard Toe in>>>?<<<
Steve Weiss is offline
Old 08-10-2008, 09:44 AM
  #1367
tantalus007's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Nexus Racing
The Reedy pack does not fit in the 008 well at all. If you install it with the humps down, it rubs against the spur gear. If you install it with the humps up, the pack becomes extremely tall.
Either way, there is some grinding + shimming needed (unless you are comfortable hanging the pack way off of the chassis).
what if i grind one side of the humps... will the pack avoid rubbing the spur when the humps are facing down???
will i still need to shim the top deck once ive done this???
tantalus007 is offline
Old 08-10-2008, 03:11 PM
  #1368
yokemad's Avatar
@Steve
Cheers DUde
yokemad is offline
Old 08-10-2008, 03:15 PM
  #1369
Nexus Racing's Avatar
You'll still need to shim. The pack is pretty tall compared to the Trakpower/Orion/Core batteries.
Nexus Racing is offline
Old 08-11-2008, 04:15 PM
  #1370
draggin87's Avatar
Trader Rating: 33 (100%+)
Default 008
alright, i picked up a U.S. spec 008. im going to be running a 17 turn motor. Im having trouble finding the right size pinoin gear. The car has a 116t 64p spur. If anyone could point me in a direction, that would be awsome
draggin87 is offline
Old 08-11-2008, 05:29 PM
  #1371
Team EAM
Trader Rating: 79 (100%+)
Anyone got to run much 13.5 on foam tires yet? Trying to figure out what size spur I will need for Vegas!
EA
EAMotorsports is offline
Old 08-11-2008, 05:31 PM
  #1372
Team EAM
With a 27 turn motor we run around a 31-32 on carpet. With 19 turn its pretty close to the same or 1 tooth larger on the pinion. I would start with a 30 and see how that runs.
EA
Old 08-11-2008, 06:15 PM
  #1373
Trader Rating: 90 (100%+)
EA
104 RW from nexusracing.com
RBLove is offline
Old 08-11-2008, 07:27 PM
  #1374
draggin87's Avatar
Default 008
thanx for the help! ill try it out
Old 08-11-2008, 07:29 PM
  #1375
adamge's Avatar
I use a 100t in my foam 13.5 008. If it was out there, I would prefer a 96t simply to get the pinions smaller. 104t should work.
adamge is offline
Old 08-11-2008, 07:51 PM
  #1376
treky11's Avatar
Is anyone running the MaxAmps packs in their T2 08?
If not, why?
treky11 is offline
Old 08-11-2008, 10:03 PM
  #1377
lbckevin's Avatar
Trader Rating: 107 (99%+)
Max amps batteries are good bashing batteries, not matched style for racing.
I run the SMC 4000 pack and highly recomend it.
lbckevin is offline
Old 08-12-2008, 03:06 AM
  #1378
i am thinking about buying a t2 008 eu 6 cell for my team to run at the SIR 24hour enduro coming up in october. i read that people were having issues with the belts lasting for a couple of runs. i need to know will the belts be able to survive for a full 24 hours with a 13.5 without having to be replaced?
King of Bearing is offline
Old 08-12-2008, 04:06 AM
  #1379
Trader Rating: 16 (94%+)
LOL - since these cars and their parts are not designed for around a 24-hour enduro, I would suspect several parts that could break. Within a 24-hour enduro, you basically put 365-days worth of wear on the cars parts in 1-day.
The belts should last, but depending on track conditions (dust, rocks, etc...) they might not look to good afterwards. I would have an extra diff on hand, as well as several bearings.
kn7671 is offline
Old 08-12-2008, 06:43 AM
  #1380
mickrcarver's Avatar
Trader Rating: 101 (100%+)
I have run my 008 for 5 weekend club races at 4 heats each and have NO wear at all I would think they would be fine
mickrcarver is offline
