Team Orion Vortex Brushless motor
#108
if anyone cares, i was on the phone ealier this week with orion. i was requesting information regarding the vortex 3.5 motor, heres what i got. speeds are identical to the novak 3.5 and the lrp 3.5. Operating temps are safe up to 190 degrees and lastly the KV on the 3.5 is a touch over 8,500.. this is where i get confused, the rep told me the speeds are identical to the novak 3.5, but novak advertises there KV at 10,500 unloaded. So if the speeds are identical that would mean that the vortex 8,500 number should be loaded number.
#111
does anyone run the vortex with a mamba setup im just curious to how it performs
#114
i have a couple of questions i have a 4.5 orion it doesnt have that vortex sticker around the middle which motor is newer also i ran on a big track today with a gearing of 6.2 and the timing was turned up to the second notch but down the straight it felt like a sttock car but in the middle it was not to bad but still a little dead can any1 explain this to me plz????
#115
#116
That's a pretty tall gear ratio... What track were you at? Were you runing 6 cell? With original timing set, I would have thought 7.5 to 8 (large track + 6 cell) would have been nearer to the mark... might explain the sluggishness…
#117
Super Moderator
#118
#119
Hey guys gearing question, I just bought a Orion 10.5 BL motor I plan to use this in 4-cell 1/12th roadcourse how should I gear this motor on a 100x50 track with a 1.78 rear tire?
