Serpent to 1/10th EP Touring Kit S400
#1426
That spool aint out yet.
For foam on tarmac it might work, or not? 1/8th 4wd's use rear spool.
#1427
hi guys, i jus finished d mod race...i manage to Tq n win d race...
thanks for u guys tips....here d link of my pictures...
http://www.rctech.net/forum/showpost...postcount=3267
Wish Team serpent all d best!!!!!
#1428
kschu- congratulations!! Good job!
Butter
#1429
hi guys, i'm thinking wan turn my way into brushless system . after i play mod race for my 1st time, i notice d comm and d brush very fast finish which cost me alots!!!....
guys, any reconmended of brushless system ?? i see d speed passion GT esc nt bad, come with a controller too....wat u guys think bout it ??
thanks
thanks
#1431
Kschu= brushless system is really great. Its fast, less maintenance and runs cooler compared to brush motors. Some guys were using the Gran turismo here, while others used LRP TC Spec. I was using the Nosram ISTC Evolution ESC. So far dont have problems with the Nosram after my friend Miguel deactivate the lipo cut off which end the run early before the 5 mins time.
But Im planning to get Orion 4.5 turns... Those guys using here were really fast... So get an LRP with an Orion motor and your ready to dominate the races...
By the way, are you using the gear diff already?
Sir Randy, do you recommend using the gear diff? I hate repeated loosening and checking of ball diff frequently during races. I ordered one already.
#1432
gear diff is awsome, requires little to no maint and stay very consitent through the whole run.
#1433
Could someone with VTEC rims check track width for me, and is it possible for the wheelbase to be set at 251mm?
#1434
Rhoby- Randy is at a race testing his Serpent for the first time. I can tell you that the gear diff is amazing... very consistent diff action. Remember to change the Diff oil/lube according to track conditions. I ran a little to heavy in some low traction conditions and the car just would not hook up. The great thing is you can remove the diff, clean it, and re-fill it FAST!!
The ball diff with the new thrust bearing is much more consistent and reliable and will provide smoother action. Not to mention it will last longer.
#1435
Thanks.
#1436
As for the track requirements, tight technical tracks require very responsive steering so in theory you can run heavier fluid to make the car "react" quicker. However, the traction has to be there first so I would judge what fluid to use by the amount of traction you have and then fine tune to the specific track layout if need be.
#1438
I have not tried it but I have every intention of doing so!! I believe you can use the rear in the front but it requires some shimming to get the right offset for the belts. The only problemis that the drive shafts will be right on the edge of the drive cups. Try using 48mm drive shafts and you should be ok.
Butter
#1440
Rhoby, i didnt use d gear diff yet. but i'm using Jadd ceramic bearing n thrust bearing, it's work great for me.....i never encountered d diff screw being loose...btw, i do put a drop of thread lock liquid in d diff screw nut...this do d magic for me...
about d BL, i see a thread somewhere in rctech mention tat SP GT will lost punch after 3 minute but i'm nt sure if tat is true....BL tat in my mind now is LRP Sphere and also KO Propo BL esc(which nt yet release)....
