Serpent to 1/10th EP Touring Kit S400
#844
Shameful plug, but true nonetheless...The Parma rims normally are a hair thinner than Jaco's and may clear without cutting the steering blocks. At least that was the case when we had the same issue with the T2.
#846
#851
"The Jeff Cuffs get big in 10 days workout program"
Jeff- When you are BENCHING 300 LBS, do you use the wide grip or short grip???
Team Hic-N-Spic 4 life!!
#852
I've tried the One way in tarmac track and i've lost a lot of steering..
I've used the Hot bodies One way.. with a little bit mod..
Front spool it's much better
#855
