Alex Racing Barracuda R2 & R3
weird....i always ran TC3 springs on my Cuda with no problems on the stock shocks i just used the tc3 springs retaining on the bottom and flipped the shock collar upside-down
This is baffling me. You guys that are using the R3 shocks I have a couple more questions.
1. Do all four shocks appear to be the same size? I know it is said the longer ones go on the rear, but all of mine appear to be the same length
2. How long from top to bottom is yours? The manual and supplement said to set them to 59.5mm so that is where I am at.
One last thing, I can't find my droop screws. Where are they, like what bag did they come in? Did I miss them?
Originally posted by TC3
lowering the rollcenter will result in more chassie roll
but it will increase traction...
does anybody know, if tamiya trf shocks fit the R2 ??
thx
thx
Originally posted by OVA
Hey TC3
I'm running Tamiya shock and useing TC3 shock spring.. works great
PS. Don't use tamiya spring they're alittle too long.
Hey TC3
Re: HELP PLEASE
Originally posted by Merciless
I'm sure this has been asked b4 but i don't think a full answer has ever been given !!
When using the XENON front C-Hubs on my R3 i have an issue with ground clearence, well lack of it, the Hubs make contact with the wishbones very soon stoping there downward travel keeping the chassis within about 3mm of the ground when using worn foams.
Is there anything that can be done to help with this problem or is a change back to the std. C-hubs ??
Only thing i could think of was to take a dremel to the shoulders of the alloy C-hubs to narrow them allowing more movement ?!?!
that just seems alittle drastic ??
sorry mate, i'm not using the xenon parts yet (only the strapping tape) so can't comment on that. If not wrong, they come with 2 holes or something. Have you tried putting back the stock ones and see what is the difference?
Re: Re: HELP PLEASE
ANYONE ???
ANYONE ???
merciless,
you are correct. for running smaller tires (like foams) you'll need the arms to be able to fall down more than with rubber tires just to get a decent ride height. i have the xenon hubs as well, but i haven't used them yet. i have mounted them up, and i have verified that the interference that you speak of is, indeed, present.
the only solution is to dremel either the arm or the carrier. the arm is cheaper, but there is much more material on the carrier to grind. it won't be pretty, but with some care, and some polishing wheels you could smooth it out nice. sorry, but the low roll center pin location in the hub, which is the only one it has, is the primary cause of this. just take away some of that huge shoulder on the carrier.
pumpkin - your r/h problem is a result of a spring that is too long for your current hardware. the first thing you can do is to use associated spring perches. they drop the spring down like 3 or 4 mm or so. unless they will hit your arms, that's the easiest solution. make sure that the next springs you get fit over the shoulder of the collar. that will give you an extra mm or two. losi's are big, but they aren't much shorter if any.
i did talk to latif michail from trinity, at the roar nats last week, who had a nice set of short springs that come in or near all the ranges the associated set does. he may have said that trinity was distributing them. i can't remember the brand. his username on this board is TEAM BUTTER. i was hounding him for some, but he just blew me off.
see what yo can do.
see what yo can do.
why not use alex springs, the work very well
yeah, that sounds like an overlooked solution. i know that a lot of companies don't make springs that go stiff enough for high bite carpet. i guess i thought that might be the case here since your suggestion was, well, obvious.
lol if ur needin some stiff springs run the associated whites there liek the hardest springs iv seen thats if they will fit properly on cuda shocks
merciless,
see what yo can do.
merciless,
see what yo can do.
