Alex Racing Barracuda R2 & R3
#9721
Re: Re: R1 with R2 chassis
Originally posted by Ko Racer
you can use the R2 chassis with your R1 and not have to change the upper deck. for the R3 no can do really with out some mods to the bottom plate
Thank you fo the info!!!
Then I'll go for the R2 chassis!!
#9722
You could always buy a nice second hand Barracuda R2 Xenon Stage 3
$480 plus postage may sway me to parting with it, but only maybe
It's going so well at the moment and it's had so much cash sunk into it.
Had to Pro 4's turn up at the club tonight, they didn't run them in races though since they had one ways in and one ways don't go well on wooden floors
I checked the one ways freeness and it seemed to have a bit more drag than my cuda did when new, not had the one way in for a long time so no idea what it's like now.
#9723
#9724
R/C Tech Elite Member
Originally posted by rtypec
More than likely, he doesn't know how much public knowledge it's supposed to be so he's been tight lipped about it. FMW was supposed to make a statement in the RROC thread two weekends ago but hasn't done so as of yet.
#9725
I know this sounds a bit awkward, what would I expect to happen if i switch the oneway at the rear and a diff at the front? Would it be twitchy and most importantly would it work?
#9729
I tried an FF car (with rear tractionless), it is pretty much easier to take corner deeper. I just havent tried it with touring because of the wheelbase and speed are much difference.
Why I ponder this idea is to get the simplest change of setup between tight and open track.
I'll try it when I redo my bearings. Thanks!
#9731
Originally posted by R/C Anonymous
putting a one way in the back wouldnt that just spin in the rearof the car and not hook up at all?
#9733
you're right. I'll keep that in mind...wonder what will happen during braking...
