Yokomo MR-4TC SD
The stock spur in the sdw is a 70t. after i rebuild the diffs in my sdw with graphite gears i found i had to reshim the diffs. ended up with one shim on either side of the diff.
i built mine according to the directions, shims and all, follow the part that says bolt the bulkhead to the chassis before tighting the output or is it input shaft plate. mine was silky smooth outof the box. lots of roll time. if you look really really close you will see the tooth number on the outer ring part of the spur gear. i rub mine with a marker so its easier to read and i know which one i'm using at the time.
set up for sd
hey i know this has been asked thousand times - setup for pavement - what springsto run frt/ rr -toe in or out ,camber +/-degree - shock piston -oil wt . heres it current set up untested by me what i know it will run take off cs27 - stock motor - it has a 71 th spur gear - 23 pinion - white springs up front and yellows in rear -no sway bars - shock pistion ? oil wt? it was ran on carpet before I own it . car is free had a few bent axle but they where replace . everthing is staight as far as I can see after putting on my setup station. well let me know where to start by the way i have to of these cars want one to be a 19t car same or different set up thanks mike
Will the SDW front arms and shock tower fit an SD, just broke mine today and thought I'd get the worlds ones if they'd fit?
Thanks Matt.
I had a rear shock tower on the front, but after the break only had the standard one to put on. Car actually felt better, so will keep with the standard front tower.
Re: set up for sd
I see you're from Toms River, my wife is from Forked River
yokomo tires
can anyone tell me the difference between 138 g2 rubber tires and 139 g2 rubber tires and what sort of difference there is on grip and durabilities
Re: yokomo tires
tires
cheers just looking for more grip, what about inserts would it be different ratings for different track temp or which would be best medium or hard, whats the diffrence
Rear belt
does any one know id the rear belt of of a 1/12th yokomo mrt4c, will fit a 1/10th yokomo mrt4c sd? i can see any difference with the car is just that the chassis is shorter (thus the dront belt would be shorter)
can any one back up my theory? or do i just test it out and hope for the best?
manawatau race next weekend
greg m are you coming down also when are the next race days in taranaki
We race 1st and 3rd Sundays, so will come down to Palmy when your race days don't clash with ours.
Re: Rear belt
Re: tires
