Yokomo MR-4TC SD
Thanx lem2, so the Tamiya shock ends (the alum. ones w/ the holes) don't work as well?
- JB
- JB
- JB
- JB
Sorry, my mistake, I meant the alum. lower spring cups w/ the holes drilled all around them
- JB
- JB
broken graphite gear
I think I have broken my graphite diff and bevel gear. All the teeth got funny shape. Will post a pic soon.
Any one has the same problem ?
yes it caqn happen but you'd need to hit pretty hard... and probably have wrong shimming in there (too loose/free).
Paul
Paul
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Bosscat
who won the endurance at tonbridge?????
Originally posted by ongbenghui I think I have broken my graphite diff and bevel gear. All the teeth got funny shape. Will post a pic soon.
Paul
Paul
I was wondering to prevent this to happen again, its kinda expensive (bent a Ti Input Shafts, wreck the 1st gen. graphite shaft), would anybody consider placing an Upper Deck?
PRP, BMI or Penguin can make one?
Hello again to all Yokomo drivers!
He is another question from a new yokomo owner.
I'm looking for a setup to run rubber tires on a smooth asphalt track (traction alittle loose). The tires I would like to run are Take off c22's or c27's.
Any help would be greatly appreciated!
Thanks!
Thanks!
Ive noticed there is quite a bit of flex with the CGM without the battery in or even with the battery in as the battery mount posts are non-adjustable and the battery sits somewhat loose. When i press the battery strap down, the chassis is as stiff as a brick. Ive ordered the Tobee adjustable post and hope this solves this issue.
Johnny
Johnny
Originally posted by lem2
This happend to me once, after the Stupid Lamp post did not move out of the way!!
Go to Event Coverage and then go to 2004 Carpet Nats.
http://www.rctech.net/events/roarcar...4/index9.shtml
Wow, didn't that expect that image to be so huge.....
Thanks!
Thanks!
Johnny
Johnny
Thanks Pops!
What would be a good sorex tire to start with?
Thanks!
Thanks!
