Yokomo MR-4TC SD
Umm I ment.....
Originally posted by JayBee
i thought it is the 'E' body that's currently out?
- JB
- JB
Mabuchi540, here is how to get them right every time.
Paint up your body as you normally would, and before cutting the wheel holes, sit the body in place on the car.
Position the body how you want it, then shine a torch under the car and you'll see a shadow where the posts touch the body.
Mark the spots, drill, and you then have a perfectly mounted body.
Thanks for the info.....
i dont know how people get it so perfect !?!? i use tha torch method, and that works or placing the body posts in the right place, but thr rear body post is higher than the front and its hard to judge the wheel wells. i always mess them up only don one body perfect, my latest frewer stratus for my 200mm nitro..
try doing the rear holes first...
- JB
- JB
That's the bit I'm talking about....
Re: Umm I ment.....
Originally posted by Mabuchi540
It's the body I'm currently using. So am looking for something similar but as was mentioned above the holes aren't pre-marked so might have to get the Yokomo Chevron which I assume does have body post locations.
easiest way and the way i do it, spend the 3 bucks on a extra set of body mounts, cut them so that the uncut body sits flat on the table while over the car chassis. line up the wheels in the wells. make sure side spacing is good, and then with a marker mark on the body where the body mounts are. paint the body, cut the body, drill the holes in body, peel off paint protector wrap, done.
- JB
I put the holes in my bodies beforepainting them.
I also trim and shape them beforehand too. It makes life alot easier.
Here's a pic of my most recent effort.
I need a set-up for the Yokomo SDW with rubber tires on asphalt.
Can anyone help me?
Can anyone help me?
Hope this doesn't sound TOO dumb but....do you guy's actually drive the Worlds Edition SD ?? I'm interested in trying one but with only 555 made....I wonder if it's more of a collectors item. It looks great though !!
Can anyone help me?
Can anyone help me?
