Yokomo MR-4TC SD
SPRINGS
Does any one know how the RS springs cpmare to the normal (but shorter) Yok Springs?
i picked up the SD i had the TC3 for a few years now and i like i just want to race somthing diff! play around a lil
Matt Howard
Hi!! I was looking at your SPOOL set-up , and will copy it. My question is, did you use standard CVD's? Will the square Ti bones hold up or do you recomend using the new RS MIP CVD's in front?
And to achieve six degrees up front I will just add one (1) spacer on the front suspension mount, right?
Thanks and Stay Warm in Korea!!
Blue_74: here.....
YOKOMO RAYSPEED
Orange 18.87 Gray 19.90
Green 16.06 Red 18.25
Pink 14.93 White 17.17
Yellow 14.71 Yellow 14.87
White 12.94 Blue 14.29
Blue 12.12 Green 13.20
Blue_74: here.....
Re: Matt Howard
Matt,
Do you have a good carpet set up for the cgm or do you know anywhere I can get one?
thanks
keith
thanks
keith
Originally posted by kt racing
Matt,
thanks
keith
Matt,
thanks
keith
Re: Re: Matt Howard
Originally posted by Matt Howard
I always run the yokomo hardened universals up front. I've never tried the Ti bones or the RS CVD's so I don't know how well they'll hold up. I'm pretty sure that one "notched" spacer is equal to one degree when used under a suspension mount so you'll need two. The unnotched spacer is equal to 1 mm.
Keith why do you need a carpet setup for a cgm? Thought you went to a TC4. I'm using tosilini's cleveland setup, I think (the one with out all the mod's). You should try out my car feels like it's on rails.
Hey Matt,
Much thanks with all your help,
I went out to 4 Fun Hobbies yesterday (all day) ran about twelve packs and from what your recommended plus the stock RS setup, I was nearly perfect (at least as I have been in long while) I need to make some adjustments but only minor ones, Maybe a degree of toe or camber and tire setups, wanted to just try different bodies and gear ratios yesterday. Found what you have recommended was right there, I only went up or down one tooth. I have to say. WOW this car handles like a dream on outdoor asphalt.
I will make a trip to SoCal next week I hope and do the same thing over again but will try tire, toe, camber and spring settings as the everything else should be right with it. Any hints for SoCal I don't know if you have run there much. By the way I am going to try my first series this year (Jimmy Babcock Sedan Series which starts in April-September). I hope all this setup testing works out, as it has intimidated me for so long (which is non-sence because little changes make big results(I was making big changes and was getting horable results)) I guess I had to go back to basics. Oh well I just wanted to say thanks, not write a novel.
Thanks for listening,
Stephen <><
Stephen <><
Originally posted by Mr. Shookie
Hey Matt,
Stephen <><
Hey Matt,
Stephen <><
I might be out at SoCal next Saturday, maybe I'll see you there
Steve Wang
Originally posted by SpeedTech
Hey Stephen,
Steve Wang
Hey Stephen,
Steve Wang
Anyway if I can I see ya there.
Thanks,
Stephen <><
Shookie, are you going to do the OC circuit races? There is one in Bakersfield at showtime this sunday and i believe the next one is at hot rods.
Blake
Blake
